Question about Cell Phones
Installation, no slot for telephone cable Panasonic PQLV300 series
How to active caller id for panasonic kx-t7730
It depends what telephone system the KX-T7730 is connected to. You should have a Panasonic box that says 'KX-TA624', 'KX-TEA308, 'KX-TES824' or similar somewhere.
Depending which Telephone System you have, it may just need programming or it may need an additional card (circuit board) installing. Panasonic KX TEA TES Telephone Systems Tiny Telecom
Nov 23, 2016 | Panasonic KX-T7730 Corded Phone
Modem connection
From Page 68 of the CF19 Reference Manual:
Modem 68
<only for model with internal modem>
CAUTION
?? Do not use the PBX internal phone lines installed in company offices. Doing so may lead to a fire or electric shock.
?? You cannot connect the modem to the following lines.
• Interphone
• Intercoms
• ISDN
?? Be sure to connect the telephone cable into the modem port, not into the LAN port.
?? Use a surge protector since the modem may be damaged by a sudden high voltage surge that may occur in the event
of a lightning strike.
1 Open the cover and connect the telephone jack (A) to the computer
by using the telephone cable (included) (B).
?? Hold the cable so that the shape of the connector (C) matches the port, and
insert fully until it clicks.
2 Click [start] - [Control Panel] - [Printers and Other Hardware] -
[Phone and Modem Options] and change the settings as necessary.
NOTE
?? Do not enter standby or hibernation during communications.
?? To remove the cable, press and hold the lever and pull out.
This is everything about the modem.
Good Luck
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Sep 12, 2013 | Panasonic Toughbook 19 Notebook -...
Problem with dead phone kx-T7668 and telephone center TD816CE
The 7668 is designed for the kxtda range and wont work on a kxtd 816you need a Kxtd7431 or similar phoneRegards Steve
Feb 23, 2012 | Lands Phones
Hi local charity has been given a TDA100 telephone
What's a crone box? If you have no problem installing the system, without a manual, then you have a problem. The TDA-100 is a dealer only product. Hanging it on the wall and running cables to the Amphenol connectors is the easy part. The 16 port digital card uses the first 16 pairs of the cable that get cross cut to the second pair of an RJ-14 jack....in the USA. The 8 port and 16 port trunk cards use the first 8 and 16 pairs of the cable. The only tricky part is if you have a hybrid 8-port card. It uses the first 2 pairs of every 3-pair set for voice and data.
Your real problem is going to be programming. With a manual, but without the programming software, you're going to be very limited. If the system is already functional, you might have access to some of the programs, but you're going to find it difficult to do anything worthwhile.
I suggest you call a Panasonic engineer to finish the job.
Carl
Jul 16, 2011 | Panasonic Lands Phones
Just wondering if this phone has caller I D options
CID comes from a card installed on the phone system. In a TA series it's an xxx93 card that fits in a slot on the system board or stores in the lid of a TA-7624 and connects with a ribbon cable. In a TD, it's a TD-193 and in a TAW or TDA it's a 84893 or 5093 card. After the card is installed you need to have some programming to implement it.
Carl
Mar 29, 2011 | Panasonic KX-T7730 Corded Phone
We have Panasonic KX-T7731 telephones in our office. we have three incoming lines and approx. 7 extensions. the phone co has assured me they've turned on caller id capabilities for all three lines but...
A 3x7 system with 7731 phones tends to show that you have a TA-624/824 series system. CID is delivered to the phones via a xxx93 card and programming. In a 624 it connects to the main board via a ribbon cable and is installed in the system cover. The 82493 cards plug into slots on the main board. Once, or if, the card is installed, it needs to be turned on via programming. At the very minimum, program 900 in system programming turns it on and there are other parameters that you can adjust in the 900's.
Carl
Mar 15, 2011 | Panasonic KX-T7731 Corded Phone
I want to change the background music on my telephone system - my phone is a Panasonic kx-t7730. How can I do this?
All of your phones plug into a Panasonic Key Service Unit. The music source plugs into a port on the KSU. A TA series has 11 modular jacks on the main board and 2 1/8" jacks labeled EXT MUSIC and PAGING. Guess which one goes to the music source :-).
There will be a cable plugged into it and into the music source. That's where you change the messages or music.
Carl
Jan 21, 2011 | Panasonic KX-T7730 Corded Phone
I used to have the Panasonic KX-T7630 system in the office building we sold. I no longer have the capability of setting the entire system up - is there a way to use the phone as just a regular desk phone...
The KX-T7630 is a proprietary digital phone that will only work on panasonic phone systems. You need an analog phone if you are going to connect it directly to an outside telephone line.
Jan 19, 2011 | Panasonic KX-T7630 Corded Phone
Cell Phones Logo
352 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
