Question about Singer Sewing Machines
I seem to be threading the spool correctly, yet the needle doesn't pick up the thread.
    Brigadier General:
  • 3,006 Answers
You haven't stated the exact model, but the principle for picking up the spool thread is pretty universal.
After loading the spool into the bobbin case and correctly threading the spool, pull the thread up through the sliding cover plate to lie on the machine bed and mostly close the cover.
Lift the presser foot, thread the needle and then advance the balance wheel slowly so that the needle goes down and then returns up. If the machine is correctly threaded, correctly adjusted , has an unbent needle and the needle is appropriate to the thread size, then it should pick up the bobbin thread. Just pull on the loose end of the needle thread and the loop with the bobbin thread should come up through the needle hole. Pull both threads to the right from where they have just emerged, allowing the loose end of the bobbin thread to disappear beneath the cover plate before re-emerging through the needle hole. Close the cover fully, lower the foot onto the work and start sewing.
If the above fails, then check that the spool is loaded the correct way around into the bobbin. It makes no difference to many models, but does to some. If you don't have the instruction book then just try both ways. It also helps to ensure that the machine is correctly maintained with no build ups of lint and correctly oiled with sewing machine oil. This is a light oil grade but has additives to ensure that it sticks where it's needed, "3-in-1" brand oil can be used but may need to be applied more frequently and the machine will need cleaning more often.
If the pick up still doesn't work, then your machine needs to go for repair as it either has a damaged bobbin or a screw has come loose in the mechanism causing the machine to lose timing. For older Singer models, all of the timing and servicing information is available free on the web. Just enter your model number followed by "manual" or "service".
Good luck, please add a comment if any of my answer has puzzled you, but otherwise I'd appreciate it if you would take a moment to rate my reply.
Posted on Sep 17, 2010
  • Obertelli
    Obertelli Sep 25, 2010
    Sorry that my answer did not fully meet your expectations. May I know why? I've reviewed my answer based upon the limited information in your question and I cannot see how it could have been improved, so your feedback would be appreciated.
The top thread will not pick up the spool thread
top thread tension not tight enough
Jul 12, 2017 | Sewing Machines
My tension went out of sync now its not even picking the thread up
Try installing a brand new needle. Verify you are using the correct needle for your machine.
Remove the upper thread. Always raise the presser foot and rethread from the beginning. Make sure the threading path is correct.
Set the tension to the midway point between high & low numbers (this is usually the factory standard, although each machine may need a slight tweak and the type of fabric & thread may require a tension adjustment).
Check that the bobbin is inserted properly in the bobbin case and that the bobbin case is threaded correctly.
Retest your machine.
If it is still not picking up the bobbin thread, most likely there is a needle/hook timing issue. Take it for service.
May 15, 2016 | Janome Sewing Machines
The upper thread will not pick up bobbin thread
Make sure the needles are the correct size, fully inserted into the needle bar and oriented correctly for your machine. If that doesn't work check the timing. The hook should arrive at the needle scarf when the needle is at the lowest point in it's travel. If it doesn't... go have it timed by a pro.
Aug 28, 2012 | Singer 1507
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Top thread breaking especially when machine in reverse.
try this
The machine is not threaded correctly--rethread the machine
The thread tension is to tight--reduce the thread tension (lower number)
The thread is to thick for the needle--select a larger needle
The needle is not inserted correctly--remove needle & reinsert the needle (flat side toward the back)
The thread could be wound around the spool pin
The needle is damaged--replace
Some needles & thread are not compatible--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 03, 2010 | Singer 8280 Mechanical Sewing Machine
My Elna lotus SP (about 40 years) will not pick up thread from the spool
The needle will not pick up the bobbin thread?
Check your manual to be sure the needle is installed correctly.
On most machines this is with the flat side of the needle shaft facing the back of the machine.
Check the needle to be sure it is not bent.
Mar 18, 2010 | Elna Sewing Machines
My machine is a Brother XL5600; I think I am having a shuttle hook problem. When I lower the sewing needle to "catch" the bobbin thread and pull through- it won't catch and pull through. I have changed out...
Hi
Thanks for using FixYa. The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine according to the directions in the manual.
Place a spool of thread on a spool pin and check the upper threading.
Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
Also please check that the bobbin is installed in its case rightly. Needle thread is too tight. Hold the thread lightly to keep the end from going down into the shuttle.
The needle could be thread incorrectly. Thread the needle eye from the front to the back.
The needle could be bent or improperly inserted and install a new needle with the flat side of the needle facing the back.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Brother LS-2125 Mechanical Sewing Machine
The needle does not pick up the bobbin thread
Hi!
There may be so many reasons due to which the needle does not pick up the bobbing thread like---
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Machine problem
Hi!
There are so many reasons due to which the thread is not picking up from the bobbin like:
The upper thread could be tangled. Remove the thread completely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race.
The needle could be threaded incorrectly. Thread the needle eye from the front to the back.
Do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Bernina Activa 130
Sewing Machines Logo
208 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
