Question about Whirlpool Duet GHW9150P Front Load Washer
Dead in the water
Washing machine stopped working at end of cycle.  Was able to remove the front panel, and manually release the catch to get the clothes out, but there appears to be no power to the unit.  Verified outlet was working.
Is there an internal fuse?  Owner's manual is not very helpful .....
  • jebbly May 17, 2008
    door was not damaged; was able to find release mechanism;, just so I could get the clothes out. The cycle is long since done - the skid marks from my 3-year olds underwear are gone, so I am assuming it got pretty far along;
    At this point, the machine won't come back on - like I said, it is like there is no power to the machine - but the elec outlet definitely works -
    Again, is there an internal fuse that might be preventing power from getting through? Or perhaps a safety or kill switch somewhere that went out?
    ALBERT GARCIA May 11, 2010
    END OF CYCLE ?? you mean it went thru the WASH , RINSE , SPIN cycles then it stop working , need more infornation to assist you further , thanks AJ
  • 1,294 Answers
End of cycle? After the end of cycle you have to wait for 2 minutes minimum (or hear a click), only then you have to try the door; or your door won't open & if you force it you'll damage the door mechanism (not good). End of cycle means "your wash is done".
Pl rate if helped.
Posted on May 17, 2008
Washing cycle not working. Machine can be made to spin and empty but get to wash cycle and it shows washing/cleaning but does not move. Will fill and empty though.
No agitation?
first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ?
sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open.
If both check ok then next CHECK the motor coupler or belt if belt driven.check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 28, 2015 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Stopped with full water
Your lid switch may be bad. These fail mechanically and electrically.7ac16b8.jpgTo get to the lid switch first remove the front panel so that you can get the top loose it is bolted down. Use a putty knife and do downward force to release the front panel spring clips.8e17656.jpgRemove the top and you will see the lid switch quick connect. Unplug that and sit the top down on a work bench or table. Check the switch for mechanical and electrical failure. Set your meter to ohms and close the lid. You should have continuity. GE TRAINING MANUAL
Jul 22, 2010 | GE WBSR3140DW Top Load Washer
Hi! my GE wshing machine keeps filling with water but the wash cycle wont work. the tub isn't roating. it will advance to drain and spin if i manually do it.
sounds like the pressure switch line is plugged. remove the front panel by inserting a putty knife between the front panel and the main top an inch or so from either side to release the locking tabs. the clear tube to the left side needs to be removed and cleaned thoroughly, while the tube is removed begin filling the unit with hot water untill water comes out of the spout the tube came off of. reinstall the tube and test to make sure the water level shuts off at all levels. the largest level should stop right around the top level of tub holes.
Feb 08, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer works on any wash cycle that does not use hot water. However, if I choose a hot wash setting, it starts and begins the cycle then stops. The door is locked but the cycle stops running.
Make sure that you are getting water out of the hot side. Close both faucets, and remove the hot side washer hose. Have something at the ready to catch the water. A bucket will do fine. Inspect both ends of the hose. Usually, there is a screen there to catch any sediment. Inspect the hot connection to the solenoid valve at the back of the washer. There's usually a screen there, too. If you note any specks of debris, pull the screen(s) out and clean. Reconnect the hose to the hot faucet. Pointing the open end at the bucket, open the water valve, making sure that you are getting water there.
>> If you are getting plenty of water at the faucet and through the hose, the problem is probably the solenoid valve. Replace, but unplug the washer first.
>> If the water supply is lacking, you have plumbing issues.
Regards, --W/D--
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
I need to replace the pump on my Admiral AAV70000AWW washing machine but need a repair guide manual or instructions
Electrically Isolate the machine
To access the pump the front panel needs to be removed, first the machine top needs to be opened,
at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the internal screws on the front panel and remove the front by lifting off it the bottom brackets.
Ensure the machine is empty of water, to do this lower the waste drain pipe to floor level and clooect any water in a suitable container.
Tilt the machine back 45 degrees and remove the drive belt and bolts for the pump, remove the hoses from the pump, refit in reverse order.
Jun 08, 2009 | Maytag Admiral AAV7000A
Kenmore HE2 won't finish spin cycle
you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Wash cycle has ended and door will not unlock.
welll there are 3 screws across the bottom front of the panel (torx 15) the lower acees panel can be removed, from there you can gain access to the backside of hte lock assy and manually release it. simply run your hand up the right side, just below the lock/latch assy ther is a quarter sized/teardrop shaped pull cord. thos will release the door, for you
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
