I have a creda flash programmer 2s thermostat cotrolling my storage heaters and I have no idea how to work them.Please help as sat here freezing cold
  • 944 Answers
The thermostat controls the circuit.It opens to cool and closes when temperature is attained.
If you Air Conditioner is too cool then it is due thermostat is defective orthe thermostat sensor is defective.The thermostat is locates to front left or right side of the Conditioner based on the model.You have to remove the panel apart and check it.
Use multi meter to test the thermostat.Keep one end of the multi meter at knob top and other end at the copper wire.
Check for any changes in the reading.The thermostat will look as shown in the image.Please specify your
Air Conditioner brand name and model so i can help you more exactly.
Please check the thermostat sensor too, using multimeter.Do continuity testing on the
Ac volts too.Sensor will look like this.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 17, 2010
Honeywell cm727
Look at the heater to see if the thermostat is closing the heat relay
Feb 24, 2014 | Honeywell Programmable Thermostat Heater
Creda 79141c
Turn it off and have it checked by a registered electritan. Please DO NOT use it until you have!
Jan 28, 2014 | Heating & Cooling
No control boiler runs will not turn off at programmer if I turn wall sat no it gos off
If it turns off, in any way from the thermostat, check the programming for over lapping schedules that could keep it running.
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
Mar 18, 2013 | Hardware & Accessories
Honeywell Thermostat RTH110B
It probably has stopped outdoor unit and the blinking is to be done when working anamoni.afto heating and not to bring in cold air flashes the LIGHT as long heated air into the condenser.
Nov 01, 2011 | Honeywell Electronic Programmable...
I have a creda storage heater 79153, i turned it on on sunday night monday morning it was still cold , i changed the fuse at the wall still nothing, the only part that works is the convector heater at the...
Check the fuse board it should be marked up (but often is not especially if POLISH electricians concerned) it should be a 32 amp fuse.
The heater has a thermal fuse installed internally £12 replacement, these tend to be the only things that go wrong with storage heaters! get a qualified electrician who you trust to have a look otherwise who-ever looks at it will say its F****d and will take you to the cleaners
Oct 21, 2009 | Heating & Cooling
Over riding switch
You could have a defective thermostat causing the limit control to trip off. Here is the manual!
http://www.insinkerator.com/pdf/POU_ICU.pdf
Copy and paste to your address bar.
Jan 20, 2009 | Emerson InSinkErator W-152 Electric...
Creda T620CW condenser dryer
Recently bought condensor dryer which was working fine till the very cold weather came. Is situated in the garage so temp has been going well below freezing some nights. Now keeps switching off after a few minutes and empty water light flashes although resovoir has no water in it. Is this due ti pipes freezing?
Jul 26, 2008 | Dryers
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
Heating & Cooling Logo
243 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
