Question about HP DesignJet 5500PS InkJet Printer
Boot failed error: 1f50010 PCI Bus Error - HP DesignJet 5500PS InkJet Printer
ctf1800
  • 4402 Answers
SOURCE: hi :) plese help
remove all external devices and try again does it beep at all?
Posted on Jan 03, 2008
  • 30 Answers
SOURCE: error: 1f50010
your hard drive has gone bad you need to replace it
hope this helps :)
Posted on Oct 14, 2009
Testimonial: "Thanks"
  • 309 Answers
SOURCE: Whenever I turn on my laptop I get the Error:
You have a device that is attempting to use the same IRQ as another device that has loaded before it. Go into the device manager and look for a device that has a yellow triangle with an exclamation mark inside. You may find a couple.... Open the device properties and see if you get some indication of which other device it is having conflicts with. Then it is a matter of uninstalling one of the devices and rebooting, letting Windows re-detect the device and install it again...hopefully with the correct IRQ assignment this time.
Posted on Feb 17, 2010
TechyDrood
  • 2072 Answers
SOURCE: getting the following error on
If it is not making it to Windows at all...Generally occurs when two devices are using the same IRQ or memory allocation. This can sometimes be set in BIOS depending on the manufacturer etc. I would start by going in BIOS and restoring the default settings. There should be a menu item in BIOS usually something like "Restore Default".
If it is making it to windows then you probably just have a missing or corrupt driver. Generally this would fall under a chipset driver which can be downloaded for free from hp's site. You can also download and run Everest or SIW to properly id the device in question.
Comment back with for findings results or for more assistance.
Posted on Aug 26, 2011
  • 239 Answers
SOURCE: Error Resource conflict - PCI on Motherboard Bus:08, Device:09, function:04
see technician
Posted on Oct 07, 2012
Error: 1f50010 PCI Bus Error
1f500XX (Boot Failed)
This error is related to the Hard Disk Drive
Check that the Green and Orange LED's on the Main PCA are ON. If they are not ON, the Power Supply or its connections are defective. If the two LED's are ON and the error continues, replace the Hard Drive. If the error continues, replace the Main PCA.
Jan 16, 2013 | HP DesignJet 5500PS InkJet Printer
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND GET THIS ERROR WHEN IT TRIES TO BOOT. ERROR Resource Conflict ? PCI in slot 03 Bus:06, Deice:01, Function:00 ERROR Resource Conflict ? PCI in slot 03...
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
May 03, 2010 | Computers & Internet
Error: 1f50010 PCI Bus Error On start up the above error has appeared - any ideas
hope this helps :)
Oct 14, 2009 | Office Equipment & Supplies
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Hi :) plese help
Jan 03, 2008 | HP OmniBook XE3 Notebook
HP DesignJet 5500PS InkJet Printer Logo
1,309 people viewed this question
Seeker5211
Seeker5211
