Bought a new Maxtor Basics 500Gb external hard drive, plugged it in and it worked fine, transfered files. Rebooted my machine and now the drive won't open and keeps giving me a message telling me that the drive is not formatted and would I like to format now - losing all the transfered files! I am running Windows XP with SP3. Any advise would help thanks
  • Anonymous Jun 06, 2008
    I'm having the same problems in Windows Vista. When asked to reformat, the drive size changes (sometimes 160gb, sometimes 80gb.. it seems to be random)
    Guru:
  • 1,342 Answers
Lots of issues surfacing regarding SP3.
Have a look HERE
Posted on May 17, 2008
Maxtor 3200 hard drive not working alongside Maxtor Basics
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 21, 2009 | Maxtor Hard Drive
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor Basics 1Tb external hard drive not working
Apri il prompt dei comandi e digita cd.. e premi enter tante volte quante servono per andare in C:> ; ora digita CHKDSK X: \F dove X: dovrai sostituirlo con la lettera assegnata all'HD in cui non riesci ad entrare, premi enter. In poco tempo corregge gli errori, non si sa (almeno io) come si sono formati, e tornerai a riveder le stelle! Te lko auguro ame ha funzionato
Apr 11, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
How can I open the Maxtor Basics 500GB case??
See this link:
Mar 28, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Harddrive Disconnects
get a new external drive and transfer all the files to the new drive.
Jan 14, 2009 | Maxtor OneTouch II external hard drive...
Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
Memory loss
It seems to me that when the drive was partitioned, the whole thing was not partitioned. If using Windows XP you can go under the Control Panel, Administrative Tools, Computer Management and then Disk Management. You should be able to see the drive and if any unpartitioned space is available.
Sep 09, 2008 | Maxtor Hard Drive
500GB BAsics External USB drive
Simple Solution, Install XP on the Vista Machine...
Aug 28, 2008 | Maxtor Hard Drive
Light turns on but My Computer does not recognize the drive
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Nov 18, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
