Question about Maytag MSD2756G Side by Side Refrigerator
I have a Maytag MFI 2569 VEB and the ice maker stopped working two days ago. When I removed the ice dispenser I noticed the "ice tray" looks like it should slide out, but I am afraid to break anything. Do I need to call a repairman or can I fix this myself?
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Posted on Apr 09, 2009
smilemaker
  • 790 Answers
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
Posted on Dec 29, 2007
SOURCE: Whirlpool GD5SHAXKQ00 Ice/Water dispenser
Hey,
It's pretty easy to remove by yourself. DO NOT force it or it will probably break. Nice and easy will do it. You'll need a flat headed screw-driver and a towel.
-There are 4 retaining tabs. 2 on top and 2 on the bottom.
-Remove the drip tray in the dispenser area
-Start with the bottom. Before starting, look underneath the surround (yes--bend down, stoop or lie on the floor -- your preference) You will see 2 thin slots. That's exactly where the tabs are. Do one tab at a time.
-Place the folded towel under the surround at the same time you are placing the screwdriver tip gently at the slot---DON'T apply pressure to the screw-driver yet.
(The towel will protect the paint and by being folded will provide a slight leverage for the screwdriver) Hold the towel against the door with the same hand you're holding the screw-driver with. If you can't....then cry for help.
-With your free hand press down firmly on the lower part of the surround (where you removed drip tray from) ...at the same time GENTLY pry with the screw-driver.
It shout pop out pretty easily.
-Repeat for the other bottom tab.
-For the top tabs, lift the entire surround up and then out.
-Remove the wiring harness and VOILA!!!
-Show off to your wife.
Posted on Jul 03, 2008
SOURCE: ice and water dispenser for Maytag H20 not working
Ice 2 0 ...lights flashing and ice door flapping... i called 1-800-4maytag like someone else suggested.. they are sending me new high voltage board for free..and they will install it for free.. even though it is 2yrs old.. for once someone stands behind there product..
Posted on Sep 03, 2008
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Posted on Sep 08, 2008
Maytag MFI2665XE
The ice maker was an option that was installed where you bought the refrigerator. Most all ice makers work in a similar fashion. The device that tells when the ice tray is full may need an adjustment.
Sep 19, 2017 | Maytag Refrigerators
Ice maker inop
Water valve for ice maker may be bad. there are two valves with one supply line, one valve controls the water dispenser and one for the ice maker. you can ohm out the solenoids, it'll ohm if its good and won't if its bad
Dec 11, 2013 | Maytag Refrigerators
Ice maker, water panal on side by side refigerator not coming on when depresing handle
The water line could be frozen. Remove the water filter and see if it frozen. Also, see if the water dispenser works with the filter removed.
Sep 09, 2012 | Maytag MSD2572VEW (25 cu ft) Side by Side...
The ice maker does not seems to dispense any ice. It does have ice in the tray but won't tip into the ice bucket. Water dispenser works fine. If you turn the ice maker off and turn back on again, sometimes...
The fix to your problem is to remove the ice, warm up the tray with a hair blow dryer and thoroughly dry it. Then spray it with PAM cooking spray which is an edible lubricant. After that dries, turn on the ice maker again and the ice will dispense. Joe
Mar 08, 2010 | Fisher and Paykel E522BRXUSS Stainless...
The ice maker stopped working, gradually over a 3 day period.
It sounds like your harvesting motor failed. If you feel comfortable working on it, you can pull the ice maker out and remove the harvest motor and have it replaced. If you don't feel comfortable pulling out the harvest motor, pull the ice maker and replace the whole unit. They are a little tricky getting them out but if you take your time and don't rush, it is a doable fix for the typical do it yourselfer
Jan 11, 2018 | KitchenAid KSRB25FRBX Aluminium Side by...
Ice Maker stopped making ice - water dispenser is fine.
well first the icemaker valve and water despensor valve a separate so you might want to try but to change it out you have to change both valves cause they made together then also check and makes sure your tube is not froze up and if that aint it then change your icemaker now for a little tip the icemaker will not run as long as the freezer door is open
Dec 30, 2008 | Maytag MSD2456G Side by Side Refrigerator
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
Maytag MSD2756G Side by Side Refrigerator Logo
553 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
