Question about Foxconn 6627MA-RS2H Motherboard
I have mainboard foxconn 6627MA, i cant set the date in cmos setup, the dated always change the odds, like 2010 change to 2011 (automatacally)
  • 11,800 Answers
The battery of the BIOS is failing Replace it - it's a CR2032 model.
Posted on Sep 17, 2010
CMOS Checksum Erro
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Mar 15, 2012 | Gigabyte GA-8I865GME-775 Motherboard
M863g v5.1a sempron cmos clock error solution
Hello here is the mainboards homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=343&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
For downloading the manual.
The solulion is, to renew the cmos battery on the mainboard.
The battery is a cr2032 watch type:
Press the lid to release the cmos battery, and insert the new the same way.
Restart the pc, and you probably get this message:F1 or F2 for setup, or press the delete button to enter the bios.
You have to setup the bios, like clock,date,and boot settings for your drive.
Look in the manual, for detailed setup configure.
Good luck
Jan 19, 2012 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Why do date and time keep setting to default?
Are you sure you replaced the CMOS battery with a fresh one? Did you install it backwards (the plus side should be UP). I've only seen a bad CMOS battery cause that problem. I would try one you know is new and check the installation.
Good luck.
Dec 27, 2011 | EliteGroup ECS H61H2M2 Intel H61 Sandy...
I set date & time on my acer aspire, but it will not stay set it just stays on the date & time ive set. help! fred.
Welcome to FixYa!
-try doing these steps.
1) Enter the CMOS setup
-to enter the CMOS or BIOS setup, shutdown the computer completely -then once you press the power button to turn it on, keep on tapping on F2. (for some computer its F1, del, F10)
2)In the main or system setup screen you should be able to see the date and time. Using your arrow keys, navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
These steps may vary for your BIOS; additional help, information, and simulations can be found on the BIOS help page.
3)after you have configured the time and date, save your settings and exit.
4)if it still would'nt hold the time you have setup, it could be a possible virus issue, or the CMOS battery on your computer could be degraded.
Hope this steps would help!
Have a great day!
May 25, 2011 | Computers & Internet
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
How do i set the time on it
Settings -> Phone Setup -> Time and Date -> Set time/Date. Check that your home city is correct first Settings -> Phone Setup -> Time and Date -> Set home city ... otherwise you'll get odd daylight savings changes :)
Jun 05, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Cannot boot up and brings us the
When you power up the computer press F1 or F2 or "del " key so you see bios setup screen.
then check that your harddisk is dected or not .set time and date.
Set first boot device as your harddrive.
Then save settings and exit.
Soemtimes cmos low voltage create this error so open cpu cabinet and change cmos cell .
Then check.
Let me know if you need more assistanse.
Sep 19, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
FOXCONN 6627MA-RS2H mainboard sound driver please
download it form here:
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=6627MA-RS2H&TypeID=en-us0000004
Jan 23, 2009 | Foxconn 6627MA-RS2H Motherboard
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
Foxconn 6627MA-RS2H Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
