Question about Bamix De Luxe Hand Mixer
Dry grinder In the manual it gives a tip not to wash the dry grinder. When you grind cheese it will not wipe clean. What is the best way to clean the grinder? Can you put it in water if you need to?
  • 3 Answers
Yes - dry well after wards
Posted on Dec 22, 2008
I am looking for a wiring diagram for Hobart 4822 grinder
Ask direct. not available online.
Electrical Installation; Electrical Connection - Hobart 4822 Installation ...
https://www.manualslib.com > ... > 4822 > Installation and operation manual
  1. Cached
Hobart 4822 Manual Online: Electrical Installation, Electrical Connection. The Electrical Installation Of The Chopper Must Conform To The Local Electricity...
[PDF]4822 MEAT CHOPPER 4822 MEA T CHOPPER - Hobart
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7515.pdf
  1. Cached
  2. Similar
Page 1 of 2. 4822. MEAT CHOPPER. 701 S Ridge Avenue, Troy, OH 45374. 1-888-4HOBART ... CORD AND PLUG: A 6 foot, flexible 3 wire cord is furnished with the ... CAPACITY: 4822 will grind 16 lbs. per minute, first cutting through a 1?8" ...
[PDF]CATALOG OF REPLACEMENT PARTS
www.hobart.co.kr/data_file/4822Aug04.pdf
  1. Similar
4822 CHOPPER REPLACEMENT PARTS. F-43093 (August 2004). © HOBART. Table of Contents. 3. ELECTRICAL UNIT. 5. #22 CHOPPER ATTACHMENT ... wiring diagram for Hobart 4822 grinder Google Search
Feb 08, 2017 | Hobart Food Mixers
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I'm having oil leak out of the top of the unit? It's still working all right though, what could cause that? I don't want oil going into the mixing bowl.
It can be that the lubrication oil that was meant for the gear drives loosened off and flowed out. You can use a good wipe of the excess that have flown out, wash off with light oil and clean dry on the drive.
Occasionally you can check this to repeat the oiling and dry wiping so as to keep the top mechanism lubricated without total drying.
Sep 25, 2010 | KitchenAid K45SS Classic Stand Mixer
K5SSWW Stand mixer started slowing down while grinding shrimp
I'm not quite sure about this answer but it occurs to me that it could be the governor. It sits at the back end of the armature and as the speed control is slid to faster speeds the governor moves away from its rest position pressing against the control plate. If the governor's pivots were to be binding, even slightly, it would explain the symptoms you are describing. A service manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 28, 2017 | KitchenAid K5SS Heavy Duty Commercial...
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Black Residue on meat using Kitchenaid meat grinder attachment
This is a common issue with the Kitchenaid food grinder. The black residue is a product of the meat itself.
With Kitchenaid Food Grinder Attachments, it is recommended that the meat be partially frozen before grinding. This is to ensure a quality grind and to make sure the meat holds all its juices while grinding.
If any juices from the meat are leaked into the food grinder, the friction will cause a chemical reaction and turn the juice from the meat into a black substance.
Dec 17, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Mixer
depending on the model there is a round cover on the front of the mixer. Detach it to expose the secondary drive connection. Depending on what you are connecting to it you need to connect to the drive port and secure the accessory so it is stable. If you need instructions google kitchen aid and ask them for a manual.
Mar 19, 2008 | Food Mixers
Bamix De Luxe Hand Mixer Logo
219 people viewed this question
Top Bamix Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Bamix Food Mixer Expert? Answer questions, earn points and help others
