Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Horizontal won't stop scrolling
How do I fix the horizontal on a Hitachi Projection TV?
  • 975 Answers
YOU MEAN ITS scrolls vertically ?? either way , there should be a VERTICAL control adjust located inside , and have handy a TUNER CLEANER spray in case its dirty , to clean contact. hope this helpful , AJ
Posted on May 17, 2008
My Ultravision TV is now having horizontal lines. Do not know if it has a horizontal hold button hidden somewhere or is the TV going out? Can I fix it myself. Large screen
Can you try and see if it is your source that has the lines or the actuall TV that has the horizontal lines.
What is your source? Direct TV, Cable TV or even off air Digital TV.
If you remove your source do you still get the horizontal lines? If you do then what colors are they? Seems if when you remove your source input and you still have these H-lines then you have issues with your individual LCD palets. Especially if they are just Green, Red or Blue?
Nov 07, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
HOW TO FIXS HITACHI TV WONT COME ON RED LIGHT FLASHING PROJECTION TVI
model number?little more info...first thing check for short in power and
horizontal output transistor-common problem.also bad connection
cap in horizontal output circuit can cause blown fuse
May 28, 2014 | Hitachi Televison & Video
Why do I have rolling horizontal lines on my hitachi big screen t.v.?
Need the model number of the Hitachi which should be listed n the rear cover. I should be able to assist but will need the Model Number to determine which chassis design you have.
Apr 02, 2013 | Hitachi Televison & Video
Have a 50fx48b Hitachi TV, screen flickers, gets wavy and goes to horizontal line, smack top of tv and it goes back to normal.
This problem is a couple of bad caps in the vertical and horizontal sweep area, just can't remember which. It use to be a 220uf cap that needs changing.
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
Hitachi 65F598, Horizontal Distortion
You might can get you a schematic for the tv and troubleshoot it yourself, if you know how to use a multimeter. Check the voltages at the horizontal outputs,voltage regulator. I get mine at www.servicemanuals.net and they are the factory manuals at a low price, you download them to your computer
Feb 24, 2010 | Hitachi 65F59 65" HDTV
Won"t stay on
Something is out of tolerance in the horizontal deflection circuit. You should try resoldering the horizontal output and driver transformer. If that doesnt help you will need to troubles shoot the deflection circuits. If you need a link to get a good quality service manual for your model let me know and I will post a link.
Mar 19, 2008 | Hitachi 51F510 51" Rear Projection...
Horizontal lines and screen bounce
These sets have capacitors that will go bad, but without a good ERS meater that tests these in curcuit you could be spending a lot of time doing nothing, But the most common is to find the 9 volt reg on the signal board and change all within a 2 inches of that regulator
Feb 07, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Black Horizontal break up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 31, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
