Question about MathRescue Word Problems Of Algebra Lite
It is all about number series and this is the problem: 19.12 18.13 16.15 13.18 9.22 --------------
    President:
  • 1,187 Answers
Walter,
The next number sequence is 4.27
Here is how it is solved:
In the whole number sequence, notice how many numbers are skipped:
19, 18, 16, 13, 9, 4
19-18 = 0 skipped
18-16 = 1 skipped
16-13 = 2 skipped
13-9 = 3 skipped
9-4 = 4 skipped
Can you see how the same sequence applies to the decimal side?
Thanks for using FixYa!
Posted on Oct 21, 2010
Braun 4000 series foils
You must be careful when ordering Braun '4000 Series' foils because Braun has made two different 4000 series shaver types that do not use the same parts. For this reason you must use your full model number or type number to ensure that you select the correct parts. If you are having difficulty locating this number, see video at the link below from shaveroutlet.com
http://shaveroutlet.com/locate_model_number_tutorial/
Once you have found the correct number, you can properly select the correct parts. Below, you will find links to both types of 4000 series foils. Match your number to the list of compatible models on the item pages to select the correct one
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-4700-series-tricontrol-foil-p-349.html
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/foil-fits-braun-4000-series-flex-control-twin-control-p-145.html
Jul 23, 2011 | Braun Health & Beauty
I have a Maytag Neptune Model #: MAH5500BWW Serial #: 74920520ZZ The door refuses to close. If I slam it a few times, it eventually closes, locks, and it washes fine. I was considering replacing the lock...
If definitely sounds like you have a door latch problem. Slamming the door repeatedly, however, is probably doing more harm than good. You may be able to get the door to work intermittently for now, but eventually, the lock will stop working altogether.
You are correct. The part numbers ARE based on the Serial Number (series) when it comes to Maytag appliances. If a series is listed next to a part (series 10, for example), the part applies to all appliances that have a serial number beginning with "10" or higher. If an additional series is listed (20, for example), the part applies to all appliance that have a serial number beginning with "20" and higher.
EXAMPLE:
Series 10 (serial numbers beginning with "10 to "19")
Series 20 (serial numbers beginning with "20" to "29")
Series 30 (serial numbers beginning with "30 to "39")
So...using YOUR appliance serial number for this example, if you had a part that had several series listings, you would use the one that matches nearest to your serial number. Say, for example you had a door latch that had three different versions (series 10, 20 and 30). You would use series 30, as the number is the closest to the beginning two digits in your serial number. If your serial number began with "19", for example, you would use series "10", because the first two digits in your serial number do not exceed "20". If only one series number is listed, or if no series number is listed, it applies to ALL washers under that particular model number regardless of serial number. Confused now? So am I.
Based on the information you've provided, the part number for a replacement latch assembly for your washer is: 22004435.
You can purchase replacement parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also inclide helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. There are also helpful wiring diagrams included on some sites. Prices vary, so shop and compare.
NOTE: If your model number is not listed on some sites, use the part number from the Sears site as your search criteria. Sometimes certain model numbers do not always appear on parts websites (due to the appliance being too old, recently added model, etc.), but the part numbers generally will, because many parts are interchangeable between model numbers. If you have any questions, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Is there a difference in GE dishwasher model GDWT260RSS and GDWT260 R10SS
No difference at all. The 1 is a series number in the model number and is only needed for a technician when it is being serviced or if there happens to be a recall. The dealer web sites and ge's web site never list the series numbers in the model number to avoid confusion. But the series number will be included in the model number tag inside the machine and on your registration card.
Hope this helps!
Bob
Oct 07, 2010 | General Electric GDWT260RSS Stainless...
I want the replacement motherboard part number
The part number you posted on the FixYa site is correct for a replacement board. It is actually designed for the DV1300 series but will work iin many DV1000 series notebooks. If you get on E-Bay and put that part number in the search box, you will find many that are for sale and under 120 bucks. Good luck
Nov 25, 2009 | HP Pavilion dv1000 Notebook
None of my burners will ignite but the oven works. Gas if flowing but their is no ticking sound and no ignition.
The surface burners are ingited by individual electrodes. The electrodes get their "spark" from a spark module. If none of the electrodes are sparking, chances are, the spark module has gone bad and requires replacement.
If the model number you have this question listed under is correct, the part number is either 8215557 or 12001596. Which one you order is based on the SERIAL number of your appliance. Look at the first two numbers in your serial number. This identifies which SERIES your Maytag is. In the Example of this part, there are two series listed (Series 10 and Series 15). If the first two numbers in your serial number begin with "14" or less, the series is 10. If the serial number begins with "15" or higher, the series is 15. If you aren't sure, please let me know and I will confirm the series for you.
You can view a parts illustration of your appliance at any of the following websites by entering your model number:
Included is a printable wiring diagram as well.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Nov 03, 2009 | Maytag MGR5750 Gas Kitchen Range
Model MAH4000AWW door leaks. Has hole worn in it.
You will need to go back to your madel number. Look you a series or rev number. 10, 42 or 53. It will have one of these numbers there. This will tell you which part your looking for.
model-number-tag.jpg Please rate solution if helpful. Thanks
Aug 24, 2009 | Washing Machines
The s/n that i have on my disc wont work when i try to use it in the setup wizard so i can put my pics in my pc
ivitar Entries
May 29, 2008 | Vivitar Cameras
Computers & Internet Logo
311 people viewed this question
Top MathRescue Computers & Internet Experts
Computer Links
Piyal Perera
Piyal Perera
raysaw
Are you a MathRescue Computer and Internet Expert? Answer questions, earn points and help others
