Question about Mitsubishi VS-5043 50" Rear Projection Television
I have sound but no picture
I have changed a fuse that was blown out, sounds better than before but still no light and picture
  • Mitsubishi Master
  • 8,617 Answers
Sounds like a problem with the vertical output IC causing the tubes to be blanking as a protective measure, that could have been responsible for the fuse being blown as well if the The other possibilities are shorted capacitor or diode in the vertical deflection circuit.
Posted on May 17, 2008
Installed new lamp on my hitachi60v715 no picture or sound
Possible power supply or Lamp Ballast that has instantly blown a fuse.
If no power or lights etc someone has to open and test voltages etc.
If beyond you---have set taken to a shop---a house call is usually a waste of time and money in this situation.
May 17, 2012 | Hitachi 60V710 60" Rear Projection HDTV
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
We have sound and can change channels and volume but absolutely no picture
There's no picture because the back lights is not function cause of faulty back light Inverter.The Inverter have blown surface mounted fuses due to shorted transistor/ ic, or transformers.
Oct 01, 2011 | Element Electronics FLX3210 32 in. LCD TV
I turn my tv on and i have sound but not 1 bit of picture i have try tons of things please help
The problem is no back lights.If the back lights is not working the back lights inverter is the cause of that, there's a blown surface mounted fuses or leak capacitor.So its better to check the back lights inverter board and find the blown surface mounted fuse cause of shorted transistor or transformer.Hope it will help you.Thanks..
Sep 04, 2011 | Televison & Video
Loud pop
If there was a loud pop then it would appaer a fuse has probably blown either on power supply especially if there is no indicator light showing. If you are getting the red stand by light then possibly a different fuse on the sustain board has blown. You would need to remove the rear cover & check any of the fuses. Most likely if they have blown something more serious has occured to cause & replacing the fuse will result in it blowing straight away.
Jul 26, 2009 | LG 42PX5D 42 in. Plasma HDTV
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
TV wont come on
Check fuse.
Is this a LCD, Plasma ect...
Do you have sound?
If LCD and you have sound use a flashlight, shine on screen check for faint picture. If you see picture the problem is the backlight has failed, check inverter board for blown fuse.
Jan 09, 2009 | Televison & Video
No picture or sound on tv
This sounds like a power supply problem. Check for a blown fuse in the unit. If there is no blown fuse then the power supply might have a shorted or open component in it. Check for the blown fuse first if the fuse is not blown or it can not be fixed by changing the fuse then the next culprit is the power supply, you will have to have a qualified TV technician do this.
I hope this helps
Thank you
shuttle83
Jul 17, 2008 | GPX KCL8806DT 7 in. Portable Television
No picture no sound only the power light turn on and off
Hmm, sounds like a fuse has blown, and this is a problem that I recommend only those comfortable around high voltages try to fix......
Dec 22, 2007 | RCA F36650 36" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
