Check ink v163 - Office Equipment & Supplies
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. make sure there is no other conflicting softwares in the pc specially recently downloaded programs. If so uninstall them too. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels( full- as it is new cartridge)
Now make a test to see if the PC commands the printer. If there is no response, check the head assembly/ ink carriage to be struck or outof alignment. Check for possible realignment of any of these mechanical problems, the ink carriage drive.
If not check the power supply unit for sub voltages to the main board. If all these are fine the main board can be faulty.
Posted on Sep 17, 2010
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
I am getting the following error. 09,038,46:15008
09,038,46:15008
Ink count flag stuck after melting 2.5 Black Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Troubleshooting Procedure
1 Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes) Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
2 Test the appropriate Ink Melt Heater. Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
4 = Black
Did the test pass?
Yes) Replace the Printhead
No)Replace the Ink Loader.
Sep 08, 2011 | Xerox Phaser 8560/YN Printer
I have an MX300 printer. Whenever I try to copy, the screen reads v163 col. What does this mean?
Hey!!
Its telling you that the colour cartridge is empty or remaining ink unknown,the way to stop it is to press and hold down the stop button for about 7 seconds!!That disables the remaining ink volume detection.
Hope it helps!!
"remember to vote please"
Sep 06, 2011 | Canon MX300 Office All-In-One Printer
My xerox phaser 8560 MFP is showing system error 09,037.45:54135 and I can't figure out how to fix the problem.
Ink count flag stuck after melting 2.5 Yellow Ink Sticks.
Initial Actions
Step 1.Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 2.
Step 2.Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt [1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
Aug 03, 2011 | Office Equipment & Supplies
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
2. Test the appropriate Ink Melt Heater.
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Aug 03, 2011 | Xerox Phaser 8560MFP Laser Printer
I want to check ink levels. It is blurring the color when printing
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Jun 21, 2011 | HP LaserJet CP1518 Printer
How do I check my ink levels
Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
Let me know if you have any other questions. Please rate this solution. Thanks.
Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
Oct 05, 2010 | Office Equipment & Supplies
Error Message V163
well col probably stands for color.....i would try unplugging your printer for 10 seconds then plugging it back in....that resets the printers memory. did you buy the right black ink cartridge? that might throw a error code.
Sep 22, 2008 | Canon PIXMA MX310 All-In-One Printer
191 people viewed this question
jasbo
jasbo
