My TV is flashing Red, Blue, Green, Black and Gray after I pressed the PIP button on a universal remote please help, it also will not turn off unless unplugged! I have tried unplugging, holding the menu button.
  • 2 more comments
  • candacet_201 Sep 17, 2010
    I got one asking if your post were coming through
  • candacet_201 Sep 18, 2010
    Emerson LC320EMX
    Emerson LC320EMX
    Emerson LC320EMX
  • 712 Answers
The remote may not be programmed with the right code. Sometimes this may happen.
Posted on Sep 18, 2010
    President:
  • 2,777 Answers
Hmm are my posts coming through?!
Posted on Sep 17, 2010
  • 2 more comments
  • Tim Grayson
    Tim Grayson Sep 17, 2010
    Weird, ok, trying again. When you unplugged it and plugged it back in, did the Red, Blue, Green, Black and Gray keep repeating? The second you turn it on it starts in this loop? Did the PIP button on the same remote used to function correctly? Also what is the make / model of the TV you have?
    Thanks
    Tim
    When I plug the TV in the screen goes black and reads "digital TV" which is normal. Then it goes back into the loop. The PIP button on my universal remote never worked, or at least I never could get it to work. The model is Emerson LC329EMX
  • Tim Grayson
    Hmm I see, and do any buttons seem to respond whatsoever, either on the TV itself or the remote? It sounds like it is stuck in some kind of a service mode. Are you certain the model # LC329EMX is correct? I have no reference to that number at all, and when you do a google search for it, not a single result comes back, which is very very unusual. How old is this TV? I am looking for ways to get it out of that service mode, but it may require a call to Emerson to see if someone internally knows...
    Still check, also do you have the original remote for the TV or just that universal one?
    Also, you have pressed the PIP button before it sounds like, but this has never happened before I assume?
    Strange stuff indeed,
    Tim
    Im Sorry the Model Numer is LC320EMX, The TV is only about a year old. I have indeed pressed the PIP button before, and it would bring up a small box in the top left hand corner of the screen. I can't recall exactly what was in it, but I remember numbers seperated by colon's, and it said digital signal or something like that. Usually I would just press menu and it would go away. This particular time out of curiosity I pressed the up and down arrows the numbers moved, and BAM curiosity killed the cat or should I say the TV.
    President:
  • 1,284 Answers
What is the make and model number of your TV?
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
I got a universal remote for my sylvania flat screen tv. I was testing the "mode" on the remote and then the next thing I know my tv begins flashing colors red blue green white and I tried to...
I think you accidentally turned on some kinda of test pattern. Try pressing the Input button on the TV itself or the menu button. Sorry that is the best I can do.
Apr 27, 2011 | Televison & Video
Need to know what wires do what on a vrx765vd clarion
Yellow is 12 volt constant
Red is 12v switched accessory
Black is ground
White is front left positive
White/Black is front left negative
Gray is right front +
Gray/Black is Right front -
Green is Rear left +
Green/black is Rear Left -
Purple is Rear Right +
Purple/black is rear right -
Blue is Power Antenna *
Blue/White is Remote turn-on* There may only be one of these two but the do the same thing.
Orange is Illuminaton
Orange/White is dimmer
Light green is parking brake.
These are universal color codes for aftermarket radios. If anything is missing you shouldn't really need it.
Please Vote & Rate is this helps
Mar 08, 2010 | Clarion Car Audio & Video
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
I CANT GET OFF THE SET UP SCREEN , MANGNAVOX 47" TV, NO UNIV. REMOTES HAVE WORKED, PRESS THE GREEN BUTTON TO PROCEED?
The TV was turn ON for the first time or the TV reboot/reset.
Universal remotes are not as "universal" as we like them to be. They only control a very, small amount of options for the TV.
You'll need the remote that came with the TV to fix this problem because it has the special RED, GREEN, YELLOW, and BLUE buttons you need.
If you don't have the original remote, you can get one at this web site. It's the best price going right now. $29.95
http://www.magnavox.newremotecontrol.com/catalog_item.php?catnum=996500043780
Jun 01, 2009 | Toymax Magnavox 47MF437B 47 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
