Question about Makita Tools 12" Planer - 2012NB
Bought it at auction. Runs fine, blades sharp, feeds fine. But doesn't seem to cut. Like the head isn't contacting the wood. What do I do?
  • 395 Answers
The blades may not be positioned correctly in the cutting head. Check and adjust as necessary. The Makita Website may provide the information you need for this.
Posted on Sep 17, 2010
Feed extremly hard to push board thru
my be you planning to much wood at once or the cutter is dull
Mar 15, 2014 | Dewalt Planer (DW734)
Dose not cut in a straight line wonders
First question: What are you cutting? Are you cutting wood? If you're using fence, I need you to make adjustments on it . The nature of the band saw is to drift either left or right being parallel with the band saw fence. Is the blade tension too tight or insufficient? Check your manual for correct tension or you can just see in the tension gauge on your saw. Please this blog on how to check the correct blade tension . What is your feed and speed rate? Make sure the you're not feeding the wood too slow or too fast. Are you using new blade? Your blade is may be dull or low quality. I purchased my blades on www.sawblade.com . Their Haltbar 201 Series works great on general wood cutting.
Last question, have you taken up time to tune up your saw? See this blog for your reference.
Sep 11, 2013 | Craftsman Saws
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
Feb 17, 2013 | Stihl 009/010/011 Clutch/sprocket
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
The saw is producing blue acrid smoke upon use. I am using a vacuum to evacuate the shavings, but the saw itself does not seem to be cutting the wood. I am using a hardwood and feeding it slowly into the...
check the blade, it sounds like it is burning the wood instead of cutting it. I would recommend using a carbide tipped blade for the hardwood. Let me know if you need more assistnace.
Sep 11, 2011 | Ryobi Saws
My saw will cut for 5 seconds and then the blade stops spinning. When I back the blade out it starts again and the process is repeated. It takes a long time to cut wood this way. What's the problem? Is...
I would suspect a combination of the two! You blade probably isn't sharp and your saws brushes are probably getting worn. The brushes are made of carbon and are pushed up against the rotor by a spring. As the brush wears down the spring doesn't put as much pressure on the brushes which means it will stop working when placed under heavy load.
Aug 11, 2011 | Rotary Professional Grade 7.25 Inch...
My Mag77 is burning the wood it is cutting. I just changed to a new blad and it didn't seem to help ... any ideas of what I'm doing wrong?
Very stupid question and you will be forgiven for getting upset at it, do you have the blade in the right way around?
If you are using tungsten tipped blades. they are extremely sharp and create their own clearance so that the disc proper does not come in contact with the wood being cut and should not cause burning. If you have a conventional blade, the teeth have a set on them - one bent left, the next right etc. This is to once again create the necessary clearance for the disc and reduce loads on it - and to prevent burning.
So there are four possibilities, the first one which I will not repeat. The blades do not have sufficient set on them, the wood you are cutting is extremely hard and the blade is not able to move through quickly enough to prevent burning, or you are using a crosscut blade to rip with - try a combination blade.
Jan 29, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Blade does not cut straigt. How do I adjust the
There shoul be a scale and a crank or screw used to adjust the blade angle on the front of the saw blade feed bushing. Make sure you set this to 90
Feb 26, 2010 | Dewalt & Variable Scroll Saw
When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
This is difficult to describe but plan your cuts and test it out.
Cheers,
Kevin
Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Jan 25, 2010 | Saws
Makita Tools 12" Planer - 2012NB Logo
146 people viewed this question
Top Makita Crafts & Hobbies Experts
Tony Crow
Pieter Vleeshouwers
Pieter Vleeshouwers
FastHarley
FastHarley
Are you a Makita Craft and Hobby Expert? Answer questions, earn points and help others
