Question about GE Monogram ZE2160SF Convection / Microwave Oven
I have GE ZE2160 for 3 years. Recently, the ciricut breaker tripped few times. I reset circuit breaker and it is fine until tonight. It tripped again. I reset it and the LED clock is on and it works. And when I used microwave, it tripped again. But when I reset this time. the microwave is dead completely w/o LED clock. Nothings is on.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Posted on Oct 05, 2007
  • 185 Answers
SOURCE: Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Posted on Mar 25, 2008
SOURCE: microwave went bang and tripped
You probably blew the magnetron tube.
Posted on Jul 09, 2008
rylee_smith
  • 8619 Answers
SOURCE: microwave went dead
Hi
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 26, 2009
  • 211 Answers
SOURCE: microwave / Frigidare PLMV
What size breaker is protecting the circuit? Per the National Electrical Code, a microwave and a washing machine should each have their own dedicated circuit (and own breaker) rated at 20 amps. Also, if the breaker is old and has tripped many times due to continuous overloading, it may be weakened and could be tripping at a lower amperage than what it is rated. I would try the following:
1. If possible, test the microwave on another circuit and see if it trips that breaker. If possible, use a 20 amp circuit for the test.
2. If you're comfortable with working in an electrical panel safely, place a clamp on ammeter on the hot wire of the affected circuit in the panel and see how much current is being drawn when the microwave is on.
3. If you would rather stay out of the panel, get an inline ammeter/watt meter and plug the microwave into this. If the rating of the microwave is less than 15 amps (1800 watts), you may be able to use a device called a kill-a-watt at a local hardware store. This will show how much power is actually being used by a given appliance.
Posted on May 28, 2009
Opening the door tripped breaker a few times, now microwave will not power on.
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Apr 06, 2015 | GE Monogram ZE2160SF Convection /...
Samsung SMH9151 trips breaker when plugged in
You have a sort circuit inside, call a repairman or take to the repair shop
Aug 23, 2012 | Samsung SMH9151 Microwave Oven
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
We have a GE Profile microwave and every time we open the door it trips the breaker. We turn the breaker back on and use the microwave and as soon as the food is done cooking and we open the door - bam,...
For a breaker to trip, you have to have an over voltage condition that is usually referred to as a short. Since your unit works in the cook cycle and only trips the circuit breaker when you open the door the short has to be in the door latch switch or reset circuit. So it wouldn't be that hard to repair, but since it is 7 years old and not the most energy efficient unit, if you aren't able do the repair yourself, then I would replace it!
You can get an idea of how hard the repair would be by going to the searspartsdirect.com web site and putting in the model # off the ID TAG. Then look for the door latch assembly and that will give you an idea of the cost of the parts and get an idea of how hard it is to replace.
Aug 07, 2011 | Microwave Ovens
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Model JVM 1650sho1
is there a fix for this problem mine does the same thing, i changed the powerstrip and it worked fine for a month, now it's doing it again runs for too minues or so then it trips the circuit breaker in the power strip
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave JE1640WB blows circuit breaker
The problem may not have anything to do with the magnetron.
It is a device that uses DC for operation and to supply that, there is one or more heavy diodes that are more likely to fail first.
Have also seen the transformers fail occasionally too.
Frankly, it may be time to dispose of it since you will likely be billed for the repair if the magnetron is not at fault and once they have it, you don't know if the truth is being told or not.
Another possibility is a circuit breaker on its way to the grave.
If you care to go to the trouble, you might shut down the main breaker in the breaker box, swap the tripping breaker with another of the same rating and try the microwave one more time.
The surge current the microwave draws is probably a good bit higher than the hair dryer and might be enough to trip an aged breaker.
Mar 27, 2008 | GE JVM1190 Microwave Oven
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Monogram ZE2160SF Convection / Microwave Oven Logo
315 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
