Question about Siemens Washing Machines
The soap powder in my washing machine is not getting dissolved. This is a front load A07-16 electronic model.
    Brigadier General:
  • 3,006 Answers
This will be due to one of three causes.
  1. You are using an incompatible wash powder for your machine. If you're in India (the WM A 0716 was an India-only model) then some of the cheapest domestic brands are really poor quality and some of the established major brands are counterfeit products.
  2. Most powders contain some insoluble components which should be rinsed out, so the rinse cycles are not working correctly. This can happen if the wash load is too big for the machine and fails to allow space for the rinse water to circulate, otherwise it's likely a machine fault.
  3. The wash cycle is too cold. You have either selected too low a temperature or the machine has a failed heating element.
If the machine is faulty then you will need to contact Siemens for repair.
Posted on Sep 17, 2010
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
Dec 07, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Water coming out of soap tray and running down the front of the machine
Your soap tray and/or inlet is probably blocked with undissolved powder. Remove the tray and clean it. Also clean the inlet tube from the tray into the washing machine with hot water.
I, personally don't like soap powder and use a liquid or tablets because washers nowadays tend to use cold water only so doesn't fully dissolve the powder. Also the outlet to drain gets blocked along with the underground pipe to the mains sewage.
Sep 25, 2015 | Whirlpool Duet GHW9150P Front Load Washer
My washer will only dislove the powder saop on warm or hot cycle and now it won't let any water in to the tub at all why
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Your service manual and more notes on LGs HERE
Dec 09, 2010 | LG WM-2277HW Front Load Washer
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
Using powder 1/2 recommend amount. there is a continual build up of powder in the dispensing cavity behind drawer. how do I prevent this am having to clean with toothbrush daily
Hi
When you start a cycle, does the machine take a long time for it to fill up with water.
If so, you have a faulty inlet valve. There is a rubber diaphram inside the valve which tends to tear over time.When this happens the water just trickles in. Therefore the soap/powder is not dissolved into the tub thouroughly.
Some powders also dissolve less than others, and using the machine on hot water cycle helps to dissolve the soap faster.
Regards
Ash
Nov 12, 2009 | LG WM-2277HW Front Load Washer
Soap doesn't come out of clothes when I wash them on cold.
Use LIQUID soap instead. Powder does NOT dissolve fully in cold water, and may in fact BURN your clothing and ruin the pump and valves with its residue
Jun 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Feb 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Soap doesn't go out of dispenser
Make sure you are using a liquid or powder detergent made for front loading machines and has the HE symbol on the front. Also use warm water not cold some detergents may not dissolve completly
Aug 10, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
373 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
