Question about OKI MICROLINE 5521 Matrix Printer
Hi! My OKI 5521 Microline printer won't print. The alarm button flashes. What should I check?
dodgecharger
  • 254 Answers
SOURCE: Printing problems
Someone else may have an exact diagnosis on this, but here is one possibility: The printhead home sensor may be defective. This sensor, either an optical device or mechanical switch senses when the head is in the home or leftmost position. This information is used to determine start point of print. A mechanical switch will be more prone to problems, but often fixed by cleaning it. Again, someone else may have actually seen and diagnosed this problem, and could give the definitive answer.
Posted on May 10, 2007
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
  • 8 Answers
SOURCE: oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Posted on Sep 26, 2008
  • 78 Answers
SOURCE: Oki 5521 alarm light flashing.
You have a fatal error, what kind of error is specified by led combination of PRINT QUALITY and CHARACTER PITCH.
Posted on Oct 09, 2008
  • 40 Answers
SOURCE: OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Posted on Nov 29, 2008
How to change the pin head
I assume your asking how to change the "Print head" power off the machine, remove the ribbion and plastic mask (lifts up) you will see 2 gold phillips head screws. unscrew them both and lift up the print head. push in new print head and reverse the directions you removed.
Jul 24, 2014 | OKI MICROLINE 5521 Matrix Printer
Changing default settings
it's in the print settings..open up your print manager, and you'll see a button..for that..my profile has contact info if this doesn't get you there.
Mar 07, 2008 | OKI MICROLINE 591 Matrix Printer
I have an alarm light onthe display, printer does not want to print?
I have an alarm light onthe display, printer does Problem with the OKI MICROLINE 520 Matrix Printer
Dec 08, 2010 | OKI MICROLINE 520 Matrix Printer
Printer gone bezerk!!
Check the print head possible pin sticking out
Jan 05, 2009 | OKI MICROLINE 5521 Matrix Printer
Oki 5521 alarm light flashing. No other lights flashing. Nothing in manual.
Oct 07, 2008 | OKI Office Equipment & Supplies
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
OKI MICROLINE 5521 PRINTER PROBLEM
Hi. Your printer may be in a need of basic service to clear up the jamming problem. The printer has comfiguration settings. If the configuration settings are correct, then there is no need to worry - just a basic service to the rear pressure rollers and front pressure rollers. Sometimes when the printer prints for a long time over months, then there is quite a lot of build-in paper pieces inside the platten assembly. Either if it jams, often there is sometimes piece of paper stuck below the platten assembly or in between the pressure rollers...
Jun 11, 2008 | OKI MICROLINE 5521 Matrix Printer
Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
Oct 31, 2007 | OKI MICROLINE ML-395 Matrix Printer
Oki 320 turbo alarm light
check the mesage in your operating mannual
Sep 13, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 5521 Matrix Printer Logo
82 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
