hI HAVE A PROBLEM WITH MYT HP VS15 MONITOR. tHE POWER IS ON BUT THE SCREEN FLICKERS ON ADN OFF AND EVENTUALLY SHUTS ITSELF OFF...EVEN THOUGH THE POWER REMAINS ON.
i HAVE TRIED TO ADJUST THE SCREEN RESOLUTION AND HAVE ALREADY TRIED TO THE SET THE DRIVER. i HAVE UPDATE3D THE DRIV3ER AS WELL WITH NO RESULTS.
NEED HELP
this sounds like there is an internal short in the wiring cables that connect to the monitor.
Try replacing the cables if you can, if not contact Best Buy's geek squad and they can take your monitor overnight in most cases and have it back to you by the next day working perfectly fine and for little to no charge.
Recently this monitor started making the above noise as well as flickering. I am told to change the...
(More)
Recently this monitor started making the above noise as well as flickering. I am told to change the display settings back to factory settings. Cannot find this. Also, it just goes off and I have a devil of a time getting it to show a "picture" again. Any help?
I've got a wall bracket for my monitor, but can't work out how to remove the built in stand. The...
(More)
I've got a wall bracket for my monitor, but can't work out how to remove the built in stand. The only instructions in the manual are for attaching or removing the foot of the stand not the entire structure. There are four screws inside the 'neck' of the stand. I tried removing these, but it had no effect. The plastic housing was still securely fixed to the metal foot inside the moulding. Is it time to remove the case around the screen? Surely not!
