I have got a Grundig TK20, the only problem i m facing is its valves need replacement and i am unable to find the valves.
  • 37 Answers
Look up ebay of germany, ebay.de
Posted on Sep 17, 2010
Wrench code Panasonic fp7728 copier
PM service is needed. reset counter in service mode 7
Jul 18, 2014 | Panasonic Fp 7728 7850 Compatible Copier...
Screen problems with grundig GU37BLKSE
Try different video sources, if they all do the same thing then your main board is probably fried. Try resetting the TV settings in the TV menu too.
Apr 09, 2014 | Televison & Video
I am unable to turn on my Grundig. the blue power light is on but won't turn on via the remote or the button on the side The model is gu37blkse
You need to replace the electrolytic caps on nthe power supply board, or just replace the power supply,check at partstpore.com
May 26, 2011 | Televison & Video
How to set the time
Press "Memory/Time Set" (lower left corner of radio face) Display flashes Use "+" to set hour and "-" to set minutes (right side of radio face) Press "Memory/Time Set" again
Jan 16, 2011 | Grundig YB 300PE AM/FM/SW Radio
I purchased a pcv valve but I am unable to locate it on my car.3.5L engine.2005 uplander.
When facing the engine, at the drivers side top of the valve cover facing you to the right of the oil fill cap. It may not look the same when it is installed because it has a black plastic 90 degree nipple that you may have to remove and reinstall on the new pcv valve. The pcv valve fits into a black rubber bushing in the valve cover.
Jun 14, 2010 | 2005 Chevrolet Uplander
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I am unable to eject a dvd from my grundig combi TV. I press eject & get a 'clunking' noise
There should be a small pin hole on the front of the dvd tray. Gently push the end of a paper clip into the hole and that should release the dvd tray.
Oct 07, 2009 | Grundig GU19WDVDPCX 19 in. LCD TV
Unlock region free
No Code free is available for your model so far.
Nasa..
Sep 04, 2008 | Televison & Video
Grundig TV - Tuning DVD & VCR
Hi there!
If the DVD recorder has an RF out then you should be able to tune it on UHF bandwidth. The cable should run from the RF Out on the recorder to RF on the TV. Switch the recorder on, put in a DVD and press play before tuning. Some DVD's require a disc before a Menu appears. Good Luck, Regards, JUS004
Mar 23, 2008 | Grundig GF70-600 TV
129 people viewed this question
 Grubhead
Grubhead
