Question about Toshiba e-STUDIO166 Printer
I had installed the driver but while giving test page....a message is coming that the data is sent to the printer...but by opening the printer it is showing printer is in offline......how can i solve the problem.....
    Problem Solver:
  • 6 Answers
Pls remove memory and fit in another slot
Posted on Sep 17, 2010
Document sent to printer doesn't show up in print queue. Test page goes to queue, but gets "error printing". Troubleshooter doesn't find anything. Driver is newly installed. What can I do to fix?
Is the printer selected on your computer?
Is it plugged in and switched on at the power point?
Is the printer turned on at the printer?
Does the light come on on the printer?
If all the above happens then :
Look up changeing printers in "help".
Because you did not give any information about your computer operating system I can not give any further details.
Feb 23, 2016 | Epson Stylus CX8400 Series
When I try printing I am getting a data wait message then it prints pages and pages of rubbish
Looks like you have the wrong driver installed.
Go to http://support.dell.com/, choose "Drivers and Downloads", make your way through the pages and download the correct driver for your OS.
Note: There are different drivers for 32 and 64-bit systems.
Apr 05, 2012 | Dell 5100cn Laser Printer
Uday.sourav@gmail.comMy HP DeskjetF380 all in 1 printer is not working at all. I tried millions of times but it does not start. There was no problem with the data cord. I think it is a internal problem....
check if you are having power, then if power is present after switching on does it initialize i.e ready to receive data. if yes try a self test page with the printer still disconnected from the pc. if it comes out ok connect your data cable and attempt to print a test page. if it comes out ok try a print job. if not try to change the data cable if still not working try re installing drivers. if you still dont come right try it on another pc. if nothing positive happens take it to a repair shop.
Sep 27, 2010 | HP DeskJet F380 All-In-One Printer
IR 1023 iF goed on - doen not print
re-installed the driver after deleting as administrator - power user does not seem to allow certian vista installations.deletions - geez
Jan 26, 2009 | Canon imageRUNNER 1023iF Black and White...
I can't print label from ZM400 PRINTER thru' serial port
There are a number of parameters for the serial port that have to match the pc. i would print out a config page from the printer via the menu, or power on with the cancel key held. then compare it with the settings on the pc. on the config page you should be looking for things like data bits, host control, parity etc.
Jan 19, 2009 | Zebra 170XiIIIPlus Thermal Label Printer
HP DeskJet 840c
pls. change your data cable of printer connected to computer
if it is work pls. remarks
Jan 30, 2008 | HP DeskJet 840c InkJet Printer
Printer add on
Download the driver from sharp and install this as is seems that the windows default driver is faulty. Try this
Thanks J
Sep 22, 2007 | Sharp AR-163 All-In-One Laser Printer
Blank print out
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Jan 29, 2007 | HP LaserJet 4350 Printer
Toshiba e-STUDIO166 Printer Logo
101 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
