Question about Cameras
I have a pelco model dd5tacsr I either need to findout which housing it plugs into ,or get a pinout so I can cobble up some connection myself.either way. thankyou
Plugs into Pelco BB5DOORASSY which is located in any number of pelco pendant housings.
Posted on Nov 12, 2010
I have 2 2.5mm jack ends each with different colored wires. Red and green on one and black white and orange on the other. I am hooking up a mic/ headphones. What wires connect to what
honestly the pinout for the adapter depend on what you are planning to plug it into. as manufacturers use standard plugs in different ways, usually the shoulder / body point is the shield / common connection, the others depend on what you're connecting to.
for instance I made a similar connector myself for use on a xbox 360 controller (to connect a gaming headset mic to the headset socket), I believe in that instance the mic's connection was between common and tip.
Jan 28, 2016 | Lands Phones
Where can I find an owners' manual and/or installation/set-up guide for a Pelco Model No. CCC1370H-2
[PDF]Pelco CCC1370H-2 CCC1370H-2X and MCC1370H ...
pdfstream.manualsonline.com/.../550025fc-8c14-4275-8558-aa0699ab3e5...
The CCC1370H-2, CCC1370H-2X, and MCC1370H-2 digital cameras are ... model. Eclipser Level Controls (NTSC/EIA Models Only) a. Threshold - Sets the ...
Sep 18, 2015 | Pelco Home Security
I cant find my minecraft house whats the best way to do that?
There are towns with people in them, but the houses belong to them. To get your own house you will need to began your journey mining! Collect cobble stone and wood etc. creat your house yourself. The house you create can be built any were. Use the " http://www.minecraftwiki.net/wiki/Crafting " (Mindcraft wiki) for all of your problems to be answered (=
Mar 05, 2013 | Video Game Consoles & Games
I don't know which wires to connect and to which slot it should be connected
The most important cables only FIT one plug. If it fits in one but will not fit in ANY others. Thats probably where it goes.
If you need to know which wires for your case such as front usb slots try this pinout diagram
http://image.pinout.net/pinout_files/standard-usb-pinout.gif
Otherwise you will need to be more specific.
Mar 15, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
Just got hold of a Roland R8 but no power supply - any ideas?
Well, you might try:
http://www.yub.com/products/?productID=3190411
The supply has a three pin connector and supplies +10 and -10 volts at unknown current. Don't have a pinout.
I am sure you can cobble something up if you can''t find the ACH120 official power supply.
You would need to find the pinout polarity to connect power if you have to make your own. One would taake unit apart and trace those input wires to something that would define the polarity. First find ground, then look for input filter caps which will tell you the polarity on the pins.
Jan 30, 2010 | Music
Need to replace the 9 pin male plug that goes into the woofer box,so need pinout diagram
All I wanted was a pinout diagram for the male plug so that I could wire up a new plug. Did not want to have to re-mortgage the house to get that. Thought such info would be free.
Anyway have stripped away all the plastic moulding to reveal the connections so am OK now Thanks
Jim Goldsmith
Jan 18, 2010 | Logitech X-530 Computer Speakers
I have a Pelco ES30CBW35. Rewire the 230V/115V switch and transfo
this manual should help
  1. [PDF] Pelco EH3500 Series Environmental Enclosure_service manual
go here and down load it you'll need adobe reader to view it but, you can get it for free. Best of lock Rich.
Oct 23, 2009 | Pelco ES3012 5MLZ30W Esprit High Res Black...
Why pelco Esprit hard to control?
All Pelco Esprit series must be controlled smoothly with the video termination is 75 ohm. No connected the BNC connector or wrong terminal will effect its control.
Jul 16, 2009 | Pelco ES3012-5CLZ30PW Esprit???® High Res...
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Cameras Logo
90 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
