Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
I have a Samsung washing machine model WA13R3 and it fills with water and then gives an error dE. What is it and how can i fix it. What do I look for? Thanks
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
Posted on Jan 16, 2008
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 380 Answers
SOURCE: Samsung washing machine gives Low Water pressure
You get these messages turned off by fixing the problem.
Low water pressure is basically one of the valves is not letting water pass through.
1. Do as you already did and clean the inlet filters. Any kinked hoses?
2. Adjust the water pressure in the house. Is it too high or too low?
3. Replace the valves in the unit.
4. Main board.
Posted on Dec 30, 2009
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
My samsung washing machine model SW50V3 showing dE error after its full of water, its not spinning at and even not draining as well, plz help thank you.
Did you go to Samsung site and inquire re the significance of the DE error?The machine is telling you where the problem is. Use the info and check it out.
Sep 17, 2017 | Samsung Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Error code nf
    It would really help to know the make and model of your machine as codes mean very different things depending on what manufacturer's machine they're showing on. However, I'm giong to take a blind guess that this is a Samsung? If I'm right then it means "No Flow" (Of water) you should check the following (Which I have stolen from the Samsung repair forum!)
    1. Water is shut off at rear of washing machine. Check and make sure water is turned on.
    2. Water inlet hoses are kinked or crimped. Check hose to ensure they are not kinked or crimped in any way. This will still let a small amount of water into the washer but not enough for the sensor to be satisfied.
    3. Water fill valve screens are clogged with mineral or calcium deposits. Turn the water off and remove the hoses from the "Hot" and "Cold" side. Once the hoses are removed you will see a small screen tucked inside both fill valves. The screens simply pull out so they can be cleaned. Usually it is on the "COLD" side where you'll find the clogged screen.
    4. Make sure the door is shut tightly. Yes, if the door is not shut all the way you may possibly get this error code on the display. Open and close door ensuring it closed correctly.
    If the above hasn't fixed your error, then you may have a faulty fill valve. Rather than pasting further information from the same forum, I'll just give you a pointer to it :) http://www.appliancerepairlesson.com/2014/01/11/samsung-washer-error-code-nf-fixed/
    Sep 20, 2015 | Washing Machines
    Machine has filled up with water, has DE on screen, manouvered clothing & turned off twice.u
    Hi Carol:
    The "DE error code" is indicative of a Door Error. This indicates that the washing machine door is not shutting, locking or opening.
    Here is a link to a service manual that should help you diagnose it. Keep in mind that LG models are sometimes difficult to diagnose.
    VIsit this link: LG Washine Machine Service Manual
    Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using FixYa, have a nice day.
    Feb 11, 2012 | Samsung SW62ASP Top Load Washer
    Samsung washer machine error code dE
    DE indicates a door lock error.
    Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
    Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
    Hope this helps.
    Jul 14, 2011 | Samsung Washing Machines
    Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
    m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
    Jan 17, 2011 | LG Washing Machines
    "dE" on LCD. Filled machine with bucket as water pressure is so low. Also, watewr drains immediately so I keep drain hose above water level in machine: WA80V9
    Hi
    Thanks for using FixYa. As you have not mentioned the complete model no# and the manufacturers name however, from what you have described error DE can either be drain error or door error. Door error means something is wrong with the door switch and door lock assembly. You should start by checking the door latch as well. If they are working fine then try to clean the drain hose and check the motor brushes(if the machine has motor) if they are worn can also cause this error. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    May 24, 2010 | Samsung Washing Machines
    I keep getting a nf error message. what is this
    water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
    Dec 31, 2009 | Samsung WF206ANS Front Load Washer
    Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
    105 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
