FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
Microwave oven died. (by 3 users)
posted by cogito on May 17, 2008
This is a four-year old GE microwave (hangs from a cabinet). Really dead. But power is coming to the outlet. I know there is no reset button, but is there a fuse that can be replaced or other part that I could do on my own? Or do I need a professional or even a new microwave?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 19, 2008
I have replace a fuse on the touch-control pannel and immediately the fan stops functioning and oven is not working. Its a two months old machine... the control display is working but no rotation and cooking inside is happening. please help...
Comment by Guest, posted on May 18, 2008
I saw a spark inside the microwave oven, then lost all power. Is it an internal fuse that needs replacing? I have already replaced the magnatrons.
Can a new fuse be sent to me?
John Coutts
Solution #1
posted on May 22, 2008
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2385 votes
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For most GE models, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Comment by MicrowaveSvc, posted on May 22, 2008
Clarification: The "mini-manual" may be hidden inside the unit behind the control panel or hidden on the left side behind the grille.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE CVM2072SMSS Stainless Steel 1100 Watts Microwave Oven GE JVM1350BW/WW/AW/SY Microwave Oven GE JVM1190SY/WY/AY/BY Microwave Oven GE JVM1630 Microwave Oven GE JVM1640 1000 Watts Microwave Oven GE JVM1651 Microwave Oven GE JVM1660 1000 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Panasonic NN-S753 1350 Watts Microwave Oven
cleaning interior of microwave...
we have a Panasonic 1250W... Answer This...
Emerson MW8778 800 Watts Microwave Oven
microwave won't work
microwave won't stop running,... Answer This...
Sharp R-1480 Microwave Oven
spring for the door latch is...
the door won't stay closed -... Answer This...
Microwave Ovens
it says its locked
it says its locked Answer This...
Microwave Ovens
Where is the light bulb
Where is the light bulb on... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
