I want to add an air conditioner to my coleman evcon EB17B unit in my manufactured home. What would I need to get.
  • 828 Answers
A kit is available through a Coleman Dealer sized according to the furnace you presently have installed. It should be installed by a contractor.
Posted on May 17, 2008
When my heat comes on , the blower doesn't blow it just mummes. I can turn the fan by hand and it is free. the out side unit is working . Can it be the coil on top of the fan? It a Model EB17B Coleman
It certainly could be the motor capacitor; the oval metal can located on the blower housing.
8fzzjawtltskcaaaaasuvork5cyii=
These are fairly simple to test with a digital meter that measures capacitance. Also, if it is bulged or has a hole blown in it, you know it is bad. These are available at almost any appliance parts store locally or at Grainger.com
It also could be the motor relay (#12 in the manual)
57v4aaaaasuvork5cyii=
You can download the furnace install manual and wiring diagram here:
EB17B
Grainger Industrial Supply MRO Products Equipment Tools
Jan 26, 2015 | Coleman Heating & Cooling
Flame sensor
Chances are there is a problem with the heating circuit. The blinking light is representative of identifying a problem. Look on the panel to see if it explains what each blink means.
A system that has a problem with the heating circuit will always bring the blower on and it will run continuously until someone turns it off.
Also check to see if there are safety high limit reset button on the unit that can be pressed to reset. Some manufacturers install them to alert you to a problem that needs to be corrected.
Mar 16, 2014 | Coleman Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
There is not an air filter in the unit and we have just purchased the home with the unit in it. I need to know where the filter goes, Tjis a coleman evcon central air unit
You should be able to open the lower panel on the Central Furnance unit and the filter would go against the side where the main cold air return plenum is located. There is usually either a slot/edge for the filter to slide into, or a set of clips or a wire spring that holds the filter in place, preventing it from getting sucked into the squirel cage blower.
If you want to give Coleman a call at 1-877-726-5362, I'm sure they'd send you a owners manual for your unit so you can see what periodic cleaning and such is needed to keep it working properly.
Hope you found this info helpful. Best Regards!
Aug 05, 2009 | Coleman Heating & Cooling
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
