posted by doncump on May 17, 2008
started up microwave and she quit, no power at all, checked outlet and its okay
Solution #1
posted on May 22, 2008
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
prototech@usa.net
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Danby DMW112 1100 Watts Microwave Oven
Danby DMW1146SS Stainless Steel 1000 Watts Microwave Oven
Danby DMW1406 1000 Watts Microwave Oven
Danby DMW105 Microwave Oven
Danby DMW667 Microwave Oven
Danby DMW668 Microwave Oven
Danby DMW755 Microwave Oven
Can you Help with these Microwave Ovens problems?
Repair Service
Find Microwave Oven Repairman Near You:
