Question about Lenovo 3000 Y410 Laptop
Sound not working in windows 7 - Lenovo 3000 Y410 Laptop
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 17, 2010
- re-install audio driver
- system restore
- re-install windows 7
- upgrade to vista
- HP 623913 003 Pavilion HPE H8 CTO 656599 001
Mar 15, 2014 | HEWLETT-PACKARD Hewlett Packard HP Envy 17...
Having problem with my soiud on motherboard p5sd2-vm on windows 7
The green 3.5mm audio input should be all you need. The speaker system should daisy chain. There is a speaker configurations in Windows. Go to Start > Control Panel > Hardware and Sound > Manage Audio Device > Sound. In Playback Check levels and configure speaker setup, like 2.1 or .1.
Oct 17, 2012 | ASUS Motherboard P5sd2-vm
Ibm thinkcentre 8213 sound problem for windows 7 ultimate
Sometimes the drivers are not compatible with windows 7, their are different drivers for XP and windows 7 for same hardware. So use driver finder tool to find exact drivers for the hardware. Also try a system utility tool like Reginout to fix registry and windows errors to optimize pc, maybe due to registry errors the drivers are not working. hope problem is solved.
Apr 24, 2012 | Microsoft Windows 7 Ultimate 32 bit Full...
My I-TRIGUE 3400 wont work with windows 7 unlimate 64 bit
Hello
First be sure you have downloaded and installed the correct sounddrivers.Meaning win 7 64 bit.
Not to be confused with 32 bit.You need 64 bit.
Next go to control panel,sound.Click on speakers then configure.Choose quadrophonic or 5.1.
Then run a test on each.
Also go to properties.and be sure the levels are turned up.
You may need to reboot after you do this for sound to work.
Sep 22, 2011 | Creative Labs i-Trigue 3400 Computer...
My pc sound card dose not working in window 7 and model is ct4780
Unfortunately Creative Labs has discontinued support for that model sound card. There is no Windows 7 driver as the last driver released for it was in 2005.
You'll need to purchase a newer sound card. A Windows 7 Compatible sound card starts in the $25 range.
Jan 08, 2011 | Creative Labs CT4870 / CT4780 Sound Card
Samsung Q35 notebook with Windows 7 , no sound and sony card read
Find the manufacturer of those devices and go to the manufacturer website and download the windows 7 drivers. There probabbly aren't any.
Windows 7 will use vista driver if upgrading, but not with fresh installs.
or
purchase driver magician and run the update feature.
Jan 24, 2010 | Samsung P30 Notebook
I upgraded my system from windows XP to windows 7 32 bit and sound card is not working
leobard_orn
In regards to your sound not working in Windows 7 I can tell you that Windows 7 does handle audio differently then XP did. So you will need to go to the sound card manufactures web page to get the updated drivers for Windows 7. If it is intergated on the motherboard you will need to go to their site to get the audio driver. Note since Windows 7 just came out they may not have a driver yet. However in most cases the Windows Vista drivers would be the same so if the only have Windows Vista drivers you can try them.
Hope this helps
Issken
Dec 31, 2009 | EliteGroup K7SEM Motherboard
Toshiba Satellite L25-S119 Win 7 Audio
Sorry,your sound card driver for windows 7 is not release by tosiba company.Even if they have release driver for Windows Vista too.It might have work.
So you won't be able to play audio sound on your laptop using windows 7.Either you need to downgrade to Windows XP or windows 2000 or you may get a new USB external sound card which support windows 7.
Dec 20, 2009 | Computers & Internet
I dont have sound , IL9 Pro in windows 7
This worked for me
http://downloads.guru3d.com/downloadget.php?id=2453&file=4&evp=c9eb8d63c7d7fa0e02892ef8e5c5dfb5
Sep 08, 2009 | Abit IL9 Pro Motherboard
Asus p5kc doesnt run 100% in Windows 7. I installed windows 7 but sound and network adapter doesnt work. I think windows 7 native driver didn't work. Can someone help me?
A lot of drivers will not work with Windows 7, at least for now. I would go to the Asus website and download the XP, Vista and 2000 or 2003 drivers for the sound and network cards you are trying to get to work. Try each one out. You may get one to work with Windows 7, but since Windows 7 is still BETA, I wouldn't hold my breathe.
Mar 29, 2009 | Computers & Internet
Lenovo 3000 Y410 Laptop Logo
88 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
