After changing capacitors on the supply card (cm 852 & cm 853, 2200uf 10 V, the previous were bluged), the problem is teh same. The red led of alimentation is flashing 4 times and the TV doesn't start ! What can i do know ?
  • Rommel Cana
    Rommel Cana Sep 17, 2010
    what need next is a service manual , it is not free,
    look for other output voltages such as 3.3V and insure that
    5V is running OK, it could also be on the other board
    but more details can be found on the service manual.
  • 8,457 Answers
Check all the power supply board capacitors,might mis some bad capacitors that bulges up or puffing up.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Sep 17, 2010
Channel Master Digital Analog Converter Box CM-7000
E1 is a 100 uF 16 VDC capacitor. I have been repairing these units lately and have experienced some of the same symptoms (LED goes red but doesn't transition to green after 30 seconds like it should). I have been able to repair some of these units. Make sure the power supply is working properly before spending significant time on the D2A board. The power supply is responsible for supplying 12, 5, and 3.3 VDC to the D2A board. A defective PS will measure 14.5 instead of 12, 6 instead of 5, and 2.9 instead of 3.3. The AC ripple should be about 5 mV on the 3.3 and the 5 volt supplies when loaded. The 12 volt can be as high as 50 mV on a good PS. The culprits are C12 (1000uf) and C10 (470 uf) which are the filter capacitors for the 3.3 and 5V outputs respectively. C12, the capacitor for the 3.3 V output is especially critical because it is used to feed the voltage regulator and overvoltage shutdown circuit. D7 is a hot part and can also fail sometimes. I have repaired 50% of my units just by changing these capacitors. I still have units where the D2A board is bad with a known good power supply. If anyone has more info on the D2A (like a schematic) please pass it along
Feb 25, 2012 | Televison & Video
THE TV IS DEAD, THE RED STANDBY LED FLASHES 10 TIMES INTERMITTENTLY.WHEN FIRST PLUGGED IN POWER SUPPLY RELAYS ENGAGE,THEN DISENGAGE........
Have you checked the capacitors? Before I replaced the power supply, I would replace any of the swollen capacitors and all of the transistors on the power supply
Dec 23, 2010 | Panasonic Televison & Video
42 plasma tv started experiencing the well known power off red light symptoms. Was able to power on & off for a while to get the set on. Right before the capacitors came in the TV would not power on...
Only if it is completely dead. If you have lights or LED coming on then it's not the main fuse, I would say that you changed the caps, but there are some that you missed. Look hard again and also for maybe a resistor in the power supply.
Dec 14, 2010 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My CM7000 has a red light on, and won't boot up
Most likely bad capacitors in the power supply. I have fixed several including my own. See avsforum CECB thread for more info
Mar 30, 2010 | Digi Channel Master/tal to Analog...
Hi ive been offered a techwood twp4210 plasma tv and i have a couple of questions can you advise if this is hd ready also how old are they, have also been advised that on start up it shows green sparkles...
The unit was being manufactured in the early to mid 2000's but I believe is not out of production. It is NOT an HDV. Here are the specs for the TV.
Product details Manufacturer Techwood Built-in Sat-Tuner No Compact Flash Card No Digital Tuner without Digital Tuner DVD Player / Recorder No HDTV Norm No Loudspeakers without Loudspeakers Memory Stick No Multi Channel Receiver without Multi Channel Receiver Type No Multimedia Card No PCMCIA Interface No Common Interface Slot No DVB-C No DVB-S No Screen Format 16:9 Screen Size in cm 106 cm DVI Interface No Electronic Program Guide (EPG) No Screen Size in Inches 42 in Secure Digital Card No Energy Savings Trust Feature No HD Tuner No Smart Media Card No Type of Monitor Plasma Display, Plasma Horizontal Resolution in Pixel 852 PC Interface No Vertical Resolution in Pixel 480 Brightness in Candela/m² 650 HDMI Interface without HDMI Full HD without Full HD (1080p) DVB-T without Digital Tuner HD ready Not HD Ready LED Backlight without LED Backlight DLNA certified No Energy Saving Trust Feature No HDMI No HDTV No Internet Access NO WEB CONTENT ACCESS EAN 5017416142205, 5017416183666
Nov 19, 2009 | Televison & Video
VAOVA twintuner DTR 250 GB not receiving anything since 1st October, not showing time in LED display segment, but is showing red & green lights (remote control receptors?)
Just fixed mine - replaced TIP31C (Q1 with heatsink) on power supply board. Also changed 100uF (E3) & 470uF (E4) capacitors, although probably not necessary.
Oct 08, 2009 | Televison & Video
I am having a problem with my Samsung LNT4661FX/XAA
http://techreport.com/search_google.x?cx=010312586752609289257%3Avgpois-b0yw&cof=FORID%3A11&q=LNt4661fx&sa=#692
check this link for more info on the power supply problem.
May 01, 2009 | Televison & Video
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
