Question about Sony ICF-SW100S Radio
Just need a replacement telescopic aerial for my ICF SW100. Thanks!
  • Sony Master
  • 17,129 Answers
There are many types available in the market - now being scare - but you can suit one with the same mount and size.
Some of the earlier models of cordless telephones have antennaes that can suit yourr requirement. Also check for old model radios to swap if you find there are no choices in the market.
If the old one is damaged or broken then you can mend it with mild gas welding.
Posted on Sep 17, 2010
How do I set the. Time
With the radio off, press and hold the ENTER (time set) Key DOWN. On the right side, there are 4 buttons with arrows on them. The inside ones set the timezone that you are in, the outside two will set the time. I just checked this on my ICF-SW100 and it works for me.
Mar 04, 2015 | Sony Icf-sw100 World Shortwave Receiver...
Hello. I have a Pacific PP102W radio/cassette/cd player and the aerial has broken. Any idea where I can buy a replacment? Thank you H Rosen
Go to an electronical components shop, especialized.
Ask for an telescopic aerial antenna, the same that has Pacific PP102W ( took the device to shop).
JMG
Jul 18, 2011 | Audio Players & Recorders
My Sony icf-sw100 radio has a problem with the battery hinge which will not close because the teeth of the case has worn. Can anyone solve the problem?
There are two parts involve for that problem, its either battery lid that slides up and locks and other is casing where this lid teeth go to lock.
Part numbers of both parts are appended below..
390984101 .. LID, BATTERY CASE
X33685342 .. CABINET FRONT MAIN ASSY
Click above links to get price info, both are available in partstore.com
Hope these info will help you.
Thanks.
Dec 29, 2010 | Sony ICF-SW100S Radio
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
Need to purchase new telescopic aerial for Sony, here in the uk
May have to make one up from a different radio as SONY no longer makes this model. I can search for a parts house for you but you need to email me or get me your email.
Jan 02, 2010 | Sony Audio Players & Recorders
Broken telescopic aerial on Sony radio.
The antenna is available from tritronicsinc.com (use the guest account) using part number: 1-501-712-11 for $17.47 plus shipping. There are 2 in stock.
Dan
Dec 30, 2009 | Sony Audio Players & Recorders
Telescope antenna cut apart Where I can get a new?
HELLO
You should be able to get a new telescopic antenna from any good electronics store (including online) and it is very easy to change.
All you need is a screwdriver kit with a choice of bits. Take out the screw, pull out the old antenna and you will also find 2 brass washers as well.
When you replace the antenna, put it in place then fit one brass washer at either side (it may be a bit tricky - I always use a jewellers type screw driver at this point) and when all is aligned put the screw back in and tighten it up!
JOB DONE!
Oct 16, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
My sony world radio icf-sw100 wont turn on and i just put new batteries in it
Chances are the metalic "dome" under each button in question has rotated slightly out of position. This happened with the Sync button on my post-1997 SW100. Sunddenly no Sync function and nothing about Sync on the display. The problem is easily remedied if you're into radios. literally. (A friend fixed mine.) I know several individuals who might be willing to repair your unit. E-mail me for names? paul-diehl[at character]uiowa.edu
WARNING: VERGE OF RANT
Whatever your do, DO NOT SEND YOUR UNIT TO THE SONY REPAIR CENTER IN LAREDO. I sent mine in for the Sync repair and had it returned unrepaired, with "corrosion" given as the reason. I then had an electrical engineer take a look and he correctly diagnosed the problem in 90 seconds. Took him another 30 minutes to complete the repair, which required no new parts or soldering. By the way, he found NO CORROSON WHATSOEVER anywhere in the receiver. And by the way number two, SONY LAREDO returned my receiver with major dmagage to the chassis. After three frustrating months, I was finally able to get LAREDO to replace the part of chassis they'd broken. (They 'd counted on me not taking before and after photos.) Totally incompetent, totally unresponsive, totally dishonest (they said they'd ordered a new circuit board from Japan when they hadn't), just north of outright fraud. AVOID LAREDO AT ALL COSTS.
Dec 13, 2008 | Audio Players & Recorders
Sony ICF-SW100S Radio Logo
249 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
