Question about KitchenAid KUDS50SVSS Builtin Dishwasher
Dishwasher does not fill with water. It hums as if it is trying to work.
  • KitchenAid Master
  • 17,130 Answers
If there is water in your inlet and on switch of program there is water coming into the washer, it is possible that the Hum you are hearing is the inlet valve/pressure pump that is not activating.
It might be getting warm if humming for a while and you can check this out. Remove the unit and checkit out onthe table by applying voltage for the water flow or pumping. Dirt accumulation can make it stuck and if not replace .
Posted on Sep 17, 2010
Dishwasher fills with water. then hums but dosen't clean
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishwasher does not work at all. It just makes a slight hum.
Welcome to FixYa.
It sounds like you may have a faulty fill valve or a stuck motor impeller. I guess the first obvious question is, Does the unit fill with water ? If no and it hums, faulty fill valve or water supply is off.
If it does fill with water does the humming begin after it has filled, and if so has the unit recently been idle for a period of time...say a couple of weeks or so ? If yes, the wash impeller has become stuck and there is a simply resolution for Bosch dishwashers, it's a common occurrence.
These are relevant questions and can point directly to the problem if you want to reply I can help you move forward.
Let me know what you find and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Jan 28, 2011 | Bosch SHU9915UC Dishwasher
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Asko dishwasher won't start, just hums and gets hot
Get this every few months - don't know the problem but we disconnect from unit and tilt the dishwasher and loads of stinky water spills out - from where I don't know. Then just **** all the water out of the drain bit with a chicken baster - primative but has worked every time so far. Keep trying to get water out until doesn't hum when switched on.
Dec 16, 2008 | Dishwashers
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Bought the display unit and water will not work.
hi there the low humming noise that you are getting sounds like the fill valve, this could be due to you perhaps not turning the water back on after fitting the new dishwasher or the fill hose being kinked when the dishwasher was put back ,hope this is of some help to you.
Dec 02, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
KitchenAid KUDS50SVSS Builtin Dishwasher Logo
157 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
