Question about Texas Instruments TI-83 Plus Calculator
Bottom 2 rows of buttons not working on TI-83 help
    Sergeant:
    Champion:
  • 387 Answers
Hi
i am not sure i understand your description of the problem
it could be electronic problem if not
you can reset the calculator by connect it to the computer and look which applications are running
Posted on Sep 18, 2010
My TI-83 numbers are not working properly. Rows LOG and LN are working at all.
on the back there are four spots with screws on them. take a screwdriver and remove them. then remove the front casing so that the inside of the calculator is exposed. if any of the wires are loose you can solder them back on. if nothing seems loose the physical button may be broken and you might need to get a new calculator. i would call Texas instruments to see if they will give you one for free. gl
Jun 07, 2011 | Texas Instruments TI-83 Plus Calculator
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
How do i work out the Sin, Cos, and Tan on the TI-83 plus?
First, make sure you have the appropriate angular mode set. To change the angular mode, press MODE, use the arrow keys to highlight either "RADIAN" or "DEGREE" on the third line, press ENTER, then press 2ND [QUIT].
Press the appropriate sin, cos, or tan key (two rows above the 7, 8, and 9 keys), enter the angle, close the parenthesis, and press ENTER. For example, to calculate the sin of 2.1, press
SIN 2 . 1 ) ENTER
How do I set up graph lines
in order to give the calculator a function to graph, you will want to enter the y= window by pressing the top left most button on the calculator. nintenman1.gif a menu similar to the one above will open, wherein you can enter an equation for the calculator to graph, such as (x^2-2). On the ti-83 itself, you can enter up to 9 equations to be graphed at once. after that, you may want to go to the window menu, where you can set the dimensions of the graphing plane in both the x row and y column. to view the graph, press the top right most button on the device.
hope that helps :)
Mar 29, 2011 | Texas Instruments TI-83 Plus Calculator
I'm trying to find the fraction button on my texas instrument ti 83 plus calculator and cannot find it
There is no "fraction" button on the TI-83 plus. You will have to press the divide key (2 buttons below the CLEAR key) and then use the parentheses (immediately to the left of the divide key) to tell the calculator the correct order of operations. For example, "1/3x+9" means ".333333x+9", but "1/(3x)+9" means the "x" goes on the bottom of the fraction.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
Upside down and flipped numbers
Press [CLEAR] to erase the screen. If that does not work reset the RAM
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then press [CLEAR].
If these steps fail, you should read the article.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-83 Plus Calculator
Buttons on far right row of ti-84 plus clear the screen
It seems like a harware problem. I think you shoul have the calculator repaired.
Hope it helps.
Aug 16, 2009 | Texas Instruments TI-83 Plus Calculator
The buttons in the last row will not work.
It looks like a hardware problem. You must have it repaired.
Good luck.
Jun 29, 2009 | Texas Instruments TI-83 Plus Calculator
My ti-83 plus has OS problem
That happened to me a few years ago - my friend tried to give me his operating system, and my calculator was all locked up like that for a while. There's some kind of reset code - pressing some buttons while putting a battery in - but it's been a while, so I don't remember which buttons.
Apr 15, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
185 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
