Question about ASUS P5P800-VM Motherboard
USB port does not recognize 1Mb flash drive
I have an additional card with USB ports connected to the port on motherboard with flat cable. This card recognises 256 kb flash drive, but on 1Mb card says: "USB device is not recognized". Any ideas?
Thanks, Anatoli
  • 1,066 Answers
Try connecting the card directly to your computer usb port. unplug other usb devices. if that fails, try the card in a different computer.
Posted on May 17, 2008
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
Hello, my 8gb Sandisk light is keep flashing and is not bieng reconized by my laptop.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
good luck.
Feb 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Don't detect when i connect to computer
First, make sure your iPod is fully charged and then toggle the Hold switch on and off.
Reset, Retry, Restart, Reinstall, Restore
Go through the 5 R's of iPod troubleshooting, which will often solve your issue. If you're still experiencing the issue after going through each of the steps, then continue for more suggestions.
To determine if your iPod syncs via USB or FireWire, check the table in the Additional Information section below.
Tip: If you are using Windows XP and have recently installed a Service Pack, check the Device Manager. Click the Start menu and click Run. Type “devmgmt.msc” and click OK. If no devices appear in the Windows Device Manager, go here.
Still can't see your iPod?
Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below—you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing.
Make sure your computer meets the iPod system requirements
Make sure that your computer meets the system requirements to use iPod with Windows.
If your iPod displays an exclamation point folder or sad iPod icon
If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue.
Charge the iPod and make sure it is getting power
Your iPod must have enough of a charge for your computer to recognize it. Connect your iPod to its power adapter or to a high-power port on your computer to charge your iPod if the battery is depleted. If your iPod is connected through FireWire but isn't getting power from the FireWire bus, your computer may not recognize it.
Secure the iPod's connections
Make sure that there is nothing physically inside or blocking your computer's USB (or FireWire) port, and that the cable connections to your iPod and computer are secure.
Note: If you're using an iPod shuffle (Second Generation), make sure the iPod is inserted securely in the iPod shuffle Dock.
Restart your computer
Sometimes simply restarting your computer can resolve issues.
Connect iPod to a high-powered USB port
If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer.
If you're connecting the iPod to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. Also, see iPod not recognized when connected to Windows laptop over USB to be sure that your USB ports are supplying enough power.
Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer.
Avoid connecting the iPod to a USB hub. Connect the iPod directly to a USB 2.0 port on the computer. If a hub must be used, make sure the hub is USB 2.0, and that it has its own power supply. Also, make sure the hub is connected to a high-power USB 2.0 port on your computer.
If the issue persists, try disconnecting other USB devices from the computer such as printers, cameras, scanners, external hard drives, and USB hubs to determine if there is a conflict in the USB chain.
Check whether your iPod's cable functions properly
Make sure that you are using the cable that came with your iPod. Some third-party cables may not work properly with iPod.
Make sure that nothing is in or blocking your computer's USB or FireWire port.
Check the connections to make sure that the cable is completely plugged in.
Try another known-good FireWire or USB through Dock Connector cable if available.
If swapping out your old cable for another resolves the issue, then your original cable should be replaced.
Place the iPod into Disk Mode
Try placing the iPod into disk mode to see if it is recognized by iTunes, or My Computer.
Check which format iPod is in
iTunes for Windows only recognizes Windows-formatted iPods. You cannot use a Macintosh-formatted iPod with a Windows PC. To learn for which platform your iPod is formatted, follow these instructions.
Check whether your computer's port functions properly
If another FireWire or USB port is available on your computer, try connecting your iPod to it.
If your computer recognizes your iPod after trying a different port, the original port could be faulty.
Note: iPod will not automatically wake up if you connect it to a 4-pin FireWire port. You must press the Select button (the wheel's center button) on the iPod to wake it from sleep.
Check if Windows confuses iPod with network drive
If the drive letter after iPod ("E" in most cases) is mapped to a network drive, both Windows Explorer and iTunes may exhibit strange behavior in relation to the iPod (including preventing iPod from appearing. See "Windows confuses iPod with network drive and may keep iPod from mounting or songs may seem to disappear" for more information.
Your USB or FireWire card isn't recognized by Windows
Make sure that Windows recognizes your USB or FireWire card. Follow these steps to find out if Windows sees your card.
Third-party software may be causing conflicts
Some third-party software (such as security software) may prevent your computer from recognizing your iPod.
Try adjusting the settings of such software, or temporarily disabling it, to see if that resolves the issue.
Also, try booting Windows to Selective Startup mode to disable any third-party startup programs and services, and isolate which software may be causing the issue.
Install or reinstall iTunes
Download and install the latest version of iTunes.
In some cases, you may need to completely uninstall and reinstall iTunes.
Make sure FireWire card is a WHQL-certified IEEE 1394 card
Only certain iPod models sync via FireWire. Refer to the table in the Additional Information section to make sure your iPod can sync via FireWire.
If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod.
If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this:
Go to the Windows Hardware Compatibility List website.
Click on the link that corresponds with your Windows Operating System to view the compatibility list.
Select your Operating System build, and then from the Product Categories pop-up menu, choose 1394 Controller.
Click the Search Now button.
You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP (Apple sells FireWire cards that are compatible with iPod at the Apple Store.).
To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it.
Check for a conflict in the FireWire chain
Your computer may not recognize your iPod if there's a device conflict in the FireWire chain. To see if this is the case:
Disconnect all devices from your computer's FireWire ports.
Connect your iPod to your computer's FireWire port.
If your computer recognizes your iPod, you should troubleshoot for FireWire device conflicts.
There may be an issue with your computer
If another computer is available, verify that the same issues happen with the other computer. If the other computer recognizes your iPod, you may want to troubleshoot for issues with your original computer.
Your iPod needs service
If after following these steps your computer still doesn't recognize iPod, see the iPod Service website to arrange for service.
Please Rate Me
Aug 13, 2010 | Samsung YP-U3 MP3 Player
My computer could not recognized my flash drive
try connecting the flash drive to another computer or connecting to another port connect to back port of your computer.
Jan 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Samsung external hard drive not recognized
its happens when the hard drives cable or usb port is problem
change the ccable then try
other wise plug the pci usb card & first diseble the motherboards usb port
then try
ok bye..........................................
Nov 17, 2009 | Computers & Internet
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
try using diffrent ports for it or download a driver for it by google searching
hope this helps :-)
Aug 22, 2008 | Electronics - Others
ASUS P5P800-VM Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
