Question about Kenmore 24032\24036 Top Load Washer
My type 111 washing machine was making a lot of noise and seemed to be unbalanced. But it was not. The inside kept moving around and causing a lot of noise. Now it doesn't do anything else besides fill with water. There is a low humming noise. Are there any suggestions?
  • 347 Answers
Yes it sounds like the drive block has broke or loosened up it keeps the basket centered up and provides the transfer of power in the spin cycle from the transmission to the basket..The drive block is located right under the agitator. their is a jam nut on top of the drive block that needs to be removed, then replace the drive block then reinstall the jam nut and tighten securely reinstall agitator Good Luck
Posted on Sep 17, 2010
Whirlpool type 111 washer drains won't spin. makes loud screeching noise. installed new clutch assembly. still no spin.still high pitched noise (like a belt slipping) but type 111 is direct drive
Belt slipping? is the wash tub free to turn when empty? socks and small clothing items may be jammed in the drum / tub cavity caused by overloading if its stuck. May need to strip machine and remove drum to get them out.
Don't overload machines!
Feb 03, 2018 | Whirlpool Washing Machines
I have a kenmore 800 series washer that makes a loud slamming noise at the end of the spin cycle. If you lift the lid during the spin cycle the basket slams to a halt immediately. It actually moves the...
Those parts you can check
1/ strings holding the drum were broken causing drum unbalancing when it spins.
2/ Drum bearing also gone. (noise)
3/ 3 slides that located underneath the triangle frame need replaced.
Oct 22, 2013 | Washing Machines
Tub thumps after nail wedges through small hole bottom and stops tub
You could have an unbalanced tub or the piece is rotating around in the outer tub and making the noise. Contact a professional to have the machine taken apart if the noise continues.
Jul 28, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire front loader makes banging noises in spin cycle
hi there.......if this problem has just recently appeared...its quite possible that 1 of the tub suspension springs has broken resulting in the tub lying at an angle and causing this unbalance....you can check this by tilting the machine and looking at the tub susension points
regards Sir Galahad
Aug 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Two speed auto washer - found water all over floor - no leaks on any hoses or drain. Wife said last load was unbalanced and machine was rocking around bad. Tub seems very wobbly to me when I move it...
having a very unbalanced load can cause the water to go over . yes the tubs are supposed to be able to move around some.run a load with no clothes in it if it leaks then you may have a more serious problem
Jul 26, 2009 | Whirlpool LSB6200KQ Top Load Washer
BAGGING NOISE WHEN SPINNING
try moving the clothes around it might be an unbalanced load.
Jul 30, 2008 | Tecnik TKL9260 Front Load Washer
Whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Regards
Jul 27, 2008 | Whirlpool LSB6200KQ Top Load Washer
Fwt449gfs1 unbalanced in spin cycle
there is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
May 21, 2008 | Frigidaire FWT449
Kenmore 24032\24036 Top Load Washer Logo
349 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
