Question about Frigidaire ATF6000ES Front Load Washer
Front load washer from frigidaire does not stay off! Its been blinking and beeping over and over. i press pause/cancel twice like it says on my manual but it just comes back on again. its really anoying
  • Frigidaire Master
  • 17,129 Answers
LEave it unplugged forr some time recconnecct to reset with the pause/cancel buttons.
If the beep goes on again it can be due to failure of the beep driver, maybe the logic switch.
If all your washer functions are good except for this beeping, you can disconnect the buzzer unit by desodering it.
Other wise you must check for short in the driver transistor or the logic gate so as not to replace the board.
Posted on Sep 17, 2010
Frigidaire front load washer. E46 error. replaced control board. Still have same error code. Is there a way to clear the error code and reset the washer with the new board?
Hello CJ Lou - Typically that is correct, error code E46 indicates to replace main control board. First, either unplug or flip the household circuit breaker off to the washer to reprogram it. Wait approximately ten minutes and restart unit. Then try pressing and holding the START and PAUSE/CANCEL buttons simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes. If it proves to be ineffective, contact a professional to accurately pinpoint any potentially more serious issues.
Jan 30, 2013 | Frigidaire ATF6000ES Front Load Washer
It tries to start but then the start light keeps flashing
Hello John Schmader - Sounds like the washer could be experiencing a communication error with main control board, faulty door lock assembly, pump or the timer itself is not operating correctly. Is the unit making a humming noise? If so, either the drain hose or pump is clogged and needs to be cleaned. Does the washer display an error code? Try pressing and holding the START and PAUSE/CANCEL button simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify an error (if one displays).
Jan 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Aug 19, 2012 | Frigidaire AEQ7000EG Affinity Series...
PT reads on display and it will not drain
Frigidaire does not have a "PT" technical error for any of their units. Please try to recall the error exactly by doing the following:
* Wake the washer by pressingany button.* Wait 5 seconds.* Press and hold the Start andPause/Cancel buttons simultaneously.* All LED's will go blank and after a few seconds the controlwill signal the stored code using audible beeps and blinking LED's. The controlwill repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pausebetween repeats affords you the ability to make accurate counts to identify thecorrect error codes.
Aug 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Ltf2140
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
The dryer just stopped and now wont turn on
WAIT 5 SECONDS.
Jul 28, 2012 | Frigidaire GLET1031FS Top Load Stacked...
Frigidaire gallery series front loader will not spin or drain
You really should recall the error code from the unit. Try the following and let me know if you can figure out the alpha numeric code.
WAIT 5 SECONDS.
Jul 28, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire GLFT294OES3 turns on, but after a few seconds, it goes to "No Spin" and errors out. The water won't come through and it just shuts off, please help!!!
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
You may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
My washer started beeping and the lights on the right side keep flashing
the flashing is an error code, count the number of blinks. also turn the power off. wake up the washer by touching any one bottom. then press cancel an pause buttoms at same time. it will display an error code. write that down an repost it
Jun 03, 2011 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
634 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
