Question about Applied Microphone Technology Promo Amt 1992 Geo Storm Gsi Blue
Removed all bolts for bell housing on my '91 geo storm, and still can't get it off
Are you trying to pull the motor or trans? In ether case, you may need to unbolt the stork converter. It's in between the engine and trans. Most often you can remove a pan @ bottom of bell housing.
I some cases their are all most a press fit. In witch case you will need something to pull them apart. Call the dealer, and ask one of their mechanics a bought your particular car. Most of the time they will help.
Posted on Sep 17, 2010
Install serpentine belt on 91 geo storm
I believe this is for 1.8L engine, serpentine belt. If you have a different belt for each component, that is a different issue? With multiple belts, the component usually has a pivot bolt, you loosen the bolt, then move the component to release or increase tension on the belt, then tighten the bolt.
With a serpentine belt, the tensioner does that for you.
Oct 16, 2016 | Geo Cars & Trucks
91 continental remove trans
Disconnect battery remove drive shaft, remove starter ,remove mounts undo bolts around bell housing,leave one bolt in so it won,t fall out, remove speedo wires and trans pipes if auto undo bolts to convertor put a floor jack under it and ,then remove the remaining bolt lower Trans down.
Aug 12, 2014 | 1991 Lincoln Continental
Changed the head on 91 geo storm 1.6 dohc the timing is right it sounds like it wants to fire but it won't all it does is crank over
If you don't know what you are talking about you shouldn't answer how could it be your starter if the engine is cranking over but won't start da big red truck !!!
Jul 11, 2012 | Geo Storm Cars & Trucks
Where do you conectect mto the computer on the 91 geo storm to get a reading
For 1990 Geo Storm 2+2 1.6L MFI SOHC 4cyl the OBD Diagnostic Link Connector is located front seating area, passenger side, under dash, above kick panel, mounted rear of glove compartment.
Hope helps
Apr 21, 2011 | 1991 Geo Storm
Hard time with transaxle to fix clutch
ok this is fun
you need to remove the strut lower ball joint and the trans mount then remove the motor mount from front of opisite side frame rail to allow motor to rotate
then trans will drop about 4-6 inches undo the bolts slowely arround the bell housing when all bolts out shake the bastard it will slowely slip off
remember to jack the car up high i usualy go 2 feet off the ground with swifts and geo remove the cluch cable and i believe the starter stays in place just need to undo the bolts \
this job takes about 3 hours start to finish trans drops out the botom and goes in the same way use a small jack to suport the trans untill all bolts out and dont forget to use your ball joint fork to pop the drive shafts out of the trans and btw use new fluid to replace3 your losses on the ground c
and if all else fails buy a chilton book they are a god send
May 23, 2010 | 1993 Geo Metro
91 Geo Storm, 1.6L fuel injected. Overheated on
sounds like you might have cracked the block
Jun 06, 2009 | 1994 Nissan Maxima
91 Geo Storm stuck in Park
WD-40 the HELL out of where the cable mounts to the transmission. It could have siezed by rust or corrosion...give it a try!
Also, on a side note, you may want to have all the fluids in the car serviced as its been sitting for a while. couldnt hurt!
Feb 27, 2009 | 1990 Geo Storm
How to set the timeing on 91 geo storm
The timing marks are located near the top of the crankshaft pulley on the plastic timing belt cover. There is a notch in the pulley to mark TDC (Top Dead Center)
Align the notch with the 0 mark on the plastic cover to set your base timing.
Ground the proper circuit on the ALDL connecter located under the dashboard somewhere under the steering wheel. Check the manual for the proper circuit to ground.
With the engine warm and the circuit grounded. Set the proper timing. Un-ground the circuit and you are done.
Dec 13, 2008 | 1991 Geo Storm
Removal and instalation of seats rear and front
First slide the seat to the back. You will find a bolt in the track on both sides. Remove them. Then move the seat forword and you will find 2 more bolts in the rear of the track. Be careful of the wires as you remove the seats! Frankster016
Oct 14, 2008 | 1993 Geo Storm
Applied Microphone Technology Promo Amt 1992 Geo Storm Gsi Blue Logo
105 people viewed this question
Top Applied Microphone Technology Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Applied Microphone Technology Toy Expert? Answer questions, earn points and help others
