Question about Thermador C301ZS Electric Single Oven
The control pnael has a malfunction that is causing it to beep is shows F1 and F7 as warnings and beeps and beeps. we have tried unpluggiung the oven and it continues to beep. how do we stop the beeping to start with... jefferson
thaurfen
  • 623 Answers
SOURCE: F7 trouble code
One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Posted on Nov 10, 2008
  • 327 Answers
SOURCE: we had a power outage and when the electricity was
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Posted on Jul 14, 2010
  • 417 Answers
SOURCE: my oven is beeping and the F1 code and F7 code are
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Posted on Dec 19, 2010
elix0411
  • 3530 Answers
SOURCE: This AM in my kitchen
Welcome to Fixya
Error F1 - control board failure. The error display indicates the failure of the control board. Try removing the power for one hour to see if the control board will reset its program. If same thing will happen then you need to replace the control board. You can look at thermador site for the availability of the part.
Error F7 means keypad is shorted or stucked. To resolve this issue you'll have to replace the Electronic Range control (ERC).
Thank you for using Fixya!
Posted on Jun 28, 2011
  • 1833 Answers
SOURCE: i'm at the beach so
First try this: 1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds tosee if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel. If the problem still exists, then your problem is with theEOC (Electronic oven control) or touch pad if it is separate from thecontrol...if the touch pad is separate...unplug range - access the controlpanel - remove the wiring/tape wire from touchpad to EOC...plug range backin...Leave over night...if f7 code comes back it's the EOC...if the error codeclears it's the touchpad...replace the part with the problem...if touchpadbuilt into EOC replace the EOC. Hope this helps.
Posted on Jul 15, 2011
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
Dec 19, 2010 | Thermador SC302T Electric Double Oven
I have to turm the oven off at the braker box. it comes on by itself. when I turn it on to cook it will not stay on gos off and beeps. Shows C7 or F7
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards, Diana
Jun 15, 2010 | GE JKP20 Electric Single Oven
I have a Jenn Air Oven micro combo wall unit.The oven shows an error code F1/F7 with continuous beeping. I have to turn power off to get rid of it. But then I cannot use the mocrowave-any solutions?
Hello- The code described F1/ F7 indicates a 'stuck' key on the control panel. The problem is fairly common, and is not caused by computer. The panel is actually more expensive than the computer. On site diagnosis is needed to confirm. The switch is on a circuit board behind the panel and is not serviceable. Find a good service tech in your area to check it out. Wish I had good news, but I installed several of these under 1 year warranty period.  So- let me know if this info helps- have more if needed.   Thanks- Ed
Mar 17, 2010 | Jenn-Air JJW8530C Expressions Collection...
Cleaning oven got a warning beep and an F1 indicator in light panel
F1 error code normally means the oven temperature has exceeded the safe limit for the oven and the beep is to warn you to switch off until it has cooled down.
Normally this is caused by failure of the oven temperature control sensor which then fails to cut off the power to the heating element as it should.
Sometimes it is just a 'glitch' wich can be solved by turning off the power to the oven for a few minutes and then turning back on but if the problem persists you will need to replace the sensor.
Jan 12, 2010 | Jenn-Air Ovens
Screen shows F-1 flashing . I had a clock failure previously with a F-7 trouble code . I ordered another from Sears and installed it today . Everything worked OK after the new clock assembly was installed....
We usually see F7 caused by a failure in the keypad (stuck key) and F1 caused by a failure in the control board (clock). This seems opposite to your experience. I would suggest first to power down the oven, unplug the keypad from the control board, power up the oven with the keypad unplugged. Give it some time (may take as much as 30 minutes or so), if no F1 error then problem is likely the keypad. If you still get an F1, then the problem is the control board and you should return it. If you still have trouble post your model number.
Regards,
www.fixyourboard.com
Sep 10, 2009 | GE Ovens
Error message on Kenmore oven
F-1 is not good. It basically means the EOC (electronic oven control is bad). There is a little test here for a little info:
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
F1 Error Code
try fix at http://www.fixya.com/howto/h155060-dreaded_f7_error
this is a common error and easily fixed
Dec 19, 2007 | GE Profile JTP18 Electric Single Oven
Thermador C301ZS Electric Single Oven Logo
29 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
