Question about Hobart P660 Stand Mixer
Need new gears and oil pump - Hobart P660 Stand Mixer
  • Hobart Expert
  • 119 Answers
Www.hobartservice.com Click on locate an office and type in your zip.
Posted on Mar 15, 2011
My mixer makes a grinding noise when I use it...where do I put oil in the mixer to stop the grinding sound?
The only place that could ever needs oil is the back motor bearing, and unless you are very mechanically inclined it is a major job. You need to remove all of the electrical components and the motor armature to get to this bearing.
It sounds like you may have a bad bearing. It is possible it just needs grease, but here again, this is a job for a mechanically inclined person. This involves removing the mixer head from the base and removing the lower section of the motor housing. If you do decide to do this make sure you have a new gasket and FOOD GRADE grease. These can be purchased on ebay.
I have rebuilt 10 of this style mixer. If you decide to attempt this yourself, let me know and I will give you my contact info. I will try to walk you through it. and I have one similar to yours that I have taken apart so I could send you pictures.
May 29, 2014 | KitchenAid K45SS Classic Stand Mixer
How many liters of oil?
How many liters of oil for what?
Oct 17, 2013 | Hobart Food Mixers
HELLO, My name is Timothy and I got a motor repaired for the Hobart H 600 stand mixer and I need to ask one Question. What is the gear oil that this model takes as I lost some of the gear oil during...
Planetary takes six ounces 150 weight gear oil if completely drained (i.e. Exxon Spartan EP 150 or equivalent). Transmission uses one gallon 460 weight (yeah, 460 weight!) gear oil (Exxon Spartan EP 460 or equivalent).
Jan 25, 2011 | Hobart HL600 Legacy Stand Mixer
Do th gears in a kitchenaid mixer need oil
Hi SHIRLAFINK, you do not need to 'oil' the transmission gears on a KA mixer. Your KA mixer comes with enough grease to 'last a lifetime' - whatever that means?
Depending on the age of your mixer and how heavily you use it, there may be a time when you might want to replace the grease, but that period is usually measured in years of useage.
Of course if one of the gears strips or breaks, you will need to replace all the grease when you replace the broken gear. Attempting to use salvaged grease jeopardized the remaining gears if pieces of metal or plastic debris are suspended in the old grease.
I hope this helps - hslincoln, Burke, VA
If this solution has been helpful, please rate it, thanks! hslincoln
Mar 14, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My K45SS is leaking some kind of oil or grease from the part of the mixer above where the mixer part attaches. It otherwise seems to be functioning fine.
its gear oil from the gear box that the motor turns to make the beaters turn,you need to replace the seals or keep adding food grade oil before you dry out the gearbox and ruin it
Mar 09, 2010 | KitchenAid K45SS Classic Stand Mixer
I have oil coming from the front of a hobart a200 mixer,What to look for? and what kind of oil?
If you have oil leaking from the attachment hub, the transmission grease has liquified. The transmission will need to be opened so the old lubricant can be removed, by scooping it out. There aren't any seals in the attachment hub, just two torrington needle bearings. The helical gears thrust the pinion gear onto a thrust bearing in the hub to create a seal. The hub has a return hole in it's casting for excess lube to return internally. It's possible the return hole is restricted. On the other hand, if the machine has been filled with oil, it will probably leak like a siv.
The new lube should be 35 OZ of mobil XPH 222,
Hobart part number is 103881-47 for 32OZ.
Aug 04, 2009 | Hobart A200 Stand Mixer
LEAKING OIL SEAL ON HOBART 660 CAN'T GET PLANETARY TO COME LOOSE
Definitely need to remove the acorn nut. There should then be a few thinner nuts as well. Make sure to drain the oil from planetary first and also be careful as the entire assembly is heavy. If I recall correctly, you need to be aware of a fiber gear that follows the inner gear (sun gear) and drives the oil pump that is mounted inside the planetary.
Jul 18, 2009 | Hobart Food Mixers
Model KSM90 10 speed ultra power stand mixer leaking oil at the shaft where mixer tools attach. Is there a repair kit which includes a oil seal or something like that at a reasonable price?
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
I need to change gear oil in Hobart H600 mixer.
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Feb 19, 2009 | Hobart H600 Stand Mixer
Hobart P660 Stand Mixer Logo
66 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
