Question about GE Profile PSS29NGS Side by Side Refrigerator
I have ge side by side model PSS26SGPASS it just thawed out everything in freezer, reading tc in fridge side now, freezer 37 degrees fridge was up to 50 company coming purchased 6 yrs ago help!
  • 64 Answers
I have the exact problem. My unit is 6 years old too - purchased in 2004. I have located, after cleaning the coil under the unit, this is not the source of the real problem. I took the upper cover off which houses the main logic board to find if I flicked the comp relay "compressor" the compressor then turned on. I took amp readings before and after they were .2 without the compressor running and 1.3 with the compressor on. The main board will need to be replaced. Personally I will try to locate the actual relay and replace it on the board if possible.
Posted on Dec 19, 2010
  • Slytman Dec 24, 2010
    Here are some of the pics to show the actual problem. If you an see the solder point that has been damaged it can be easily re-soldered as i did to my unit.
HOW DO I FIX
I see nothing about checking freon level .
Nov 24, 2015 | Refrigerators
Water line frozen
water tank in bottom of fridge needs to be thawed out and temps adjusted so freezer is at 4 degrees above zero and fridge should be at 37 degrees
Jan 12, 2014 | Whirlpool GS6NBEXR Side by Side...
I have a 6yrs old PSS26SGPASS GE side-by-side refrigerator that works perfectly, except for the last week or so, it started to make a constant whining noise that goes crescendo (increasingly) to a higher...
I would not call a Technician out because it will cost you too much money that you can put aside for a good refrigerator that does not have all of the electronic gadgets that keep it running GE runs behind LG with their great looks. But they both have costly failures when it come to quality electronic controls. I really hate to be honest. Wait that is what you want right? The truth is you can buy a better quality refrigerator by purchasing one that has no electronic control boards. Simple defrost timers will last 3 times longer and the pain of paying a technician to come switch your motherboard out and leave in 15 minutes with $500.00 dollars is just too much guilt for me to carry to lie
to you, Good Luck, Sea Breeze
May 11, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Feb 11, 2010 | GE Refrigerators
Veggies frozen, Ice thawed, water slow or intermittently dispens.
with out testing and or doing a full diagnostics on your unit their can be a few reasons --one is control unit ---others are slightly low on freon ---dirty condenser coil---evap frozen over with limited air flow --evap fan improper speed or frozen--damper frozen or limiting air flow or door stuck
Apr 16, 2017 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
Freezer fine- fridge temp is 51 degrees
I got the same problem. For some reason in the freezer part on the back wall there is a condensor and it keeps on getting all iced up and then there is not enough air pressure for the fan to circulate cold air to you fridge part. I took mine all apart used a hair dryer to thaw out everything which took out about 1 gallon of water from the hose in the bottom back of fridge. It fixed the problem for about 4 days and then froze up again, There must be some type of tempature sensor or automatic defroster not working like it shoud.Does anybody know? Help me too?
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Nov 22, 2008 | GE GSS25LGM Side by Side Refrigerator
GE Side by Side Refrigerator pss26sgpass - Not cooling
Hello Villaruel,
Welcome to fixya.com
I'll give you some tasks that I hope will solve your problem.
Try turning off the fridge, and unplugging it or throw off the breaker, for 5minutes!
then plug it in and turn it back on. We are trying to reset the system like when you reboot your computer. Let me know that it worked!!
Huuum,
Please do not forget to rate us before you sign off!
Thank You
Sep 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Fridge freezing in fridge area
The freezer should be set to 0 degrees and the fridge 37 degrees according to the manual. If your unit has only numbers then it would number 4 or 5 for the freezer and 6 or 7 for the fridge.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSS29NGS Side by Side Refrigerator Logo
569 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
