Question about Welding Tools
Looking to run 240v out to the garage for a welder 50a. wondring what size cable do I need to run to the panel in the garage.also have a air comp. @ 30a but dont plan on running both at the same time. panel in the garage will handle 100a do i wire it for 60a or go for 100a. aprox 40' of cable will be reqiured form house panel to garage
    President:
  • 986 Answers
To be extra safe 4 ot cooper is the best
Posted on Sep 17, 2010
Try to hook up my welding to breaker panel how many breaker do I need and what size
Typically a welder is 240v requiring a Double pole breaker, the size would depend on the equipment amps or watts?
30 amps X 240 volts = 7200 Watts
Mar 16, 2015 | Electrical Supplies
Wire schematic
If the welder is single phase 110v use a dedicated 20A standard household circuit. If 220v single phase use a 50A RV or weld receptacle connected to a 50A dual breaker with common trip. Make sure the breaker is the same brand as your panel. If the welder is 3-phase connect the wires B-O-Y (Brown Orange Yellow) at the breaker (3 phase 50A) and see if a color code match can be applied at the welder, although the only issue is whether the wire feed will run forward or reversed. If the wire feed is reversed then move any two wires of the B-O-Y set to change the rotation.
Aug 25, 2014 | Welding Tools
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
What cable is needed to supply a 9.5kw elecric shower
9500 watts is a lot of watts ... are you sure this is what is required?
Also missisng is the voltage you will be using.
Typically, a circuit of 120 volts at 20 amps is 2400 watts while 240 volts at 20 amps is 4800 watts. Either circuit would run on number 12 wire protected by a 20 amp breaker (single or double pole). You want to service a 10,000 watt load.
I am not a electrical engineer ... I think you should review the material that came with your shower and follow the manufacturers recommendation. Please read on ...
Number 8 wire should be good for 50 amp capacity. 50A X 240V = 12,000 watts. However, the distance the wire must run is also a consideration.
If this were my installation, I would beef the wire up to the next size. i.e., if the manufacturer says #8 wire, I would use #6 wire
Other things you should consider is whether the installation requires a GFI or other special breaker and special shut off switch and its location.
I hope to have steered you in the proper direction ...
Thanks for using FixYa.com
Jan 04, 2012 | Home
I need to know the circuit breaker fuse size for a flavel milano ML6CDS electric cooker and the cable rating
If your power suply is 240V and the power rating of the ovenis 9.9kw then the expected current consumption is 9900w/240v = 41.25A. Therefore this needs a 8mmsq cable or if not available in your area then use 10mmsq cable. And for the fuse or circuit breaker use 50A
Jun 14, 2010 | Ovens
Coleman aircompressor with Magnetek 115v motor....
yes you can run 220 but it has to be two 120 lines going in from oposite poles in your breaker box go to home depot and a two pole single throw breaker at least 20 amp plug that into your panel and run your cord straight to it from your comp. but you may have a bad motor the breaker will only cost you about $8 so do that and if you still have problem you have a bad motor and that is easy to change but a little more money
Jun 09, 2009 | Air Tools & Compressors
Welding Tools Logo
74 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
