Question about JVC TM-A9UCV Television
Re JVC TM-A9UCV.Picture is shrinking vertically. Please tell me where to find the adjustment. There appears to be no external control, or orifice in which to put a small screw driver. Please advise.
  • 10,515 Answers
To begin with, unfortunately, this is not a setting problem.This is an internal failure and needs to be repaired.There are plenty of circuits, however more often it is due to faulty transistors or IC's on circuit board.If you have experience in repairing electronics, could read schematics, would be able to keep all precautions, i could tell you where you could purchase the service manual and i would guide you to repair this.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 17, 2010
Picture is 1" across screen
The vertical deflection section has failed. It could be a myriad of different things and if you are not technically minded and have an oscilloscope then all you can really check is the integrity of the soldered joints, and capacitors on the circuit board. Chances are, because you have at least an inch of vertical deflection then the fault will be a capacitor that has gone out of specification, usually high. Check around the vertical section for capacitors that have the plastic wrap shrinking on them, or around heatsinks. This is usually a good place to start. Replace any suspect looking ones or remove from the board and test individually.There will not be any user friendly vertical adjustment control. Who knows you might get lucky! Good luck
Mar 21, 2014 | ESA ET432E TV
Sony KV-XJ29M50 top half vertical problem i.e shrink
Check and replace all electrolytic capacitors at its vertical output section. There will be 5 or 6 numbers. Replace all of them at the same time.
Apr 14, 2012 | Sony KV-XJ29M50 29" TV
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link www.fixya.com/users/bugoy31
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
Picture shrinks to the center and start flickering
When Posting, its a good idea to always give the make and model number.
But it appears you have a vertical deflection problem.
being that is works for a while consistantly I am to believe it is just bad solder around the vertical IC.
If you give the model number I will assist you as to what the vertical ic is. :)
Aug 21, 2009 | Sony Televison & Video
JVC D-Series TV top of picture shrinking
There are probably two capacitors that are bad in the vertical circuit. Not too hard to replace if you have any experience at all. Find the vertical output IC ( usually IC451 or similar ) and simply change the closest electrolytic capacitors. A professional can do this easily. Could cost up to $150.
May 13, 2009 | JVC AV-27D302 27" TV
Mitsubishi tv 40" cs40307 vertical shrink problem
thats problem is only a lose connection,if you know how to used a soldering iron ,solder the vertical section of your tv.
Dec 21, 2008 | Mitsubishi CS-40307 40" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Vertical probs
yoyoy, check some leaky capacitor near the vertical chip. some of this caps may have gone out of their value.
Dec 29, 2007 | JVC AV-27020 TV
Jvc model av36230
you know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
May 16, 2007 | JVC AV-36320 36" TV
Screen Size is Too Big
There should be a vertical height adjustment control potentiometer near the vertical output IC on the right side of the PC board near the front section of the TV that can be adjusted to shrink the picture vertically. Be careful not to short anything out or getting yourself shocked in the process if you decide to try to adjust it yourself. Good luck. This chassis has also been known to have bad solder connections in that area also, so don't man-handle the printed circuit board roughly.
May 23, 2007 | Zenith D32D51 32" TV
JVC TM-A9UCV Television Logo
62 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
