Question about GE GBS22HCP Bottom Freezer Refrigerator
I have GE fridge model# GBS22HBPAWW with a blown fuse on main control board any ideas? Replace control board?
    Problem Solver:
Change fuse. every fuse has a number or two on it, find a fuse with the same numbers
Posted on Sep 17, 2010
  • mistofproduc Sep 18, 2010
    Shoulda said fuse keeps blowing when plugging in I believe purple-red-blue wire clip in - the clip next to fuse area - relay below test fine -
    A short somewhere or main board shorted?
I have a GE JKP62G microwave-oven combo. The oven works fine. The microwave blew the 15 amp fuse. When I replaced the fuse, per your earlier directions, and tried to use the microwave, the new fuse blew....
Cause 1
If too much current passes through the microwave circuitry, the line fuse will blow. If the line fuse blows, the microwave won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. If you don’t resolve the underlying issue, the new fuse will blow too
Cause 2
Main Control Board
The main control board might be defective. However, this is rarely the case. Control boards are often misdiagnosed—check all of the more commonly defective parts. If you have determined that all of the other components are working properly,replace the main control board.
Cause 3
Thermal Fuse
The thermal fuse cuts off power to the microwave if the microwave overheats. To determine if the thermal fuse has blown, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. The thermal fuse cannot be reset—if the fuse is blown, it must be replaced.
Since its a electrical isue cal a liscenced professiona to resolve the issue . Your microwave oven isnt at fault . I belive the supplay to it has issue and would have blown anyway.
May 29, 2018 | GE Microwave Ovens
I have a GE fridge, it is a GSH25JSRFSS model, GH204618 serial number. It stopped working except for the light inside. I found that the main or mother board was smoked up and had a burnt place on the....
Sometimes you can call GE and get help but most times not if the year warranty has expired. I personally have never found any problems other than the board itself just having a bad relay or a circuit blown off the back. Thunderstorms are hard on them too. Below is a link for the model unit you asked about.
Main Board
May 21, 2010 | GE GSH25JFR Side by Side Refrigerator
GE GSS25QGTA Side by side fridge not cooling, no digital display, no ice or water dispensing, lights in freezer abd fridge work. Any ideas?
did you plug the fridge in and connect and turn the water pipes leading from the fridge to an outlet and water outlet, if you didn't you should
Dec 02, 2009 | Dryers
I am replacing a defective GE refrigerator main board (WR55X10416) in my GDS20SBSASS GE fridge with the newer WR5510942 main board. I have read elsewhere that a wire on this board may need to be cut,...
You should have included instructions that came with this board and the serial# is what dictates if a wire is cut or not on the main board. there also might be a wire on the harness that plugs into the wall that needs to be cut although I have yet to find one.
The provided link has pics of the instructions. just check your serial # to verify and follow the directions
GE WR55X10942 WR55X10656 Refrigerator Main Control Motherboard CB10942
cb10942-wr55x10656-wr55x10942-refrigerator-main-control-board-ge-pliqakvp0l11djscamij510i-4-0.jpg
Feb 07, 2018 | GE Refrigerators
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GBS22HCP Bottom Freezer Refrigerator Logo
218 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
