Question about Philips 42PF5321 42 in. EDTV-Ready Plasma Television
Halo, tengo un TV Plasma Philips 42pf5321d/37 con falla de imagen ya revise internamente y al alimentarla presenta falla con codigo de 4 parpadeos en led rojo. Ya fui desconectando alimentaciones en tarjetas y al quitar la de tarjeta Dynamic KSMO-VO E150630 94V-0 ya no se presenta la falla e incluso se escucha la TV pero no se ve nada. que mas pruebas puedo hacer para determinar la tarjeta daƱada o causa del problema?
5 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Encendido del LC-32GA5U
no abla espanol this is america translate your question first
Posted on May 13, 2008
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
FARADIO
  • 17 Answers
SOURCE: problema de imagen en tv philips
hola,
checate los ics de convergencia,pero que te ayude un tecnico por que estan un poco dificil de cambiar,son los stk 392-120 son dos,ok.
Posted on Feb 16, 2008
  • 10865 Answers
SOURCE: tv philips 42pf7320. prende ,peroluego
Hola! El calentamiento podr?a valer la pena el electrolytics ups con un secador de pelo antes de encenderlo. Tenido un problema similar en un plasma Philips causada por una duff condensador.
Jose'
Posted on Oct 14, 2010
Mi tv mitsubishi presenta falla al momento de ver una entrada ya sea digital ..hdmi o rca se miran rayas purpuras de lado a lado alguien me puede ayudar
Tengo un Mitsubishi 73 inch el prende pero no se ve nada en la pantalla pero se oye despues de 5 minuto prende la bombilla roja y no se ve nada ni se oye
Mar 18, 2014 | Mitsubishi WD-62525 62" Rear Projection...
LG 26LC2D will not show any picture
Buen d?a.
Tengo un televisor LG 26LC2D-ME que lo enciendo y no tiene imagen, aparece la imagen despu?s de unos minutos, cuando la vuelvo a apagar y encender tarda menos en aparecer la imagen hasta la tercera o cuarta vez que enciende normal, en ocasiones a la primera vez de encenderla tampoco apaga solamente desconect?ndola de la energ?a el?ctrica la fuente de poder ten?a algunos capacitores un poco gastados que los reemplace por nuevos estos fueron el c222 1000mf 50v, c221 1000mf50v, c234 1000mf35v, c237 1000mf35v, c201 3300mf25v,c202 3300mf25v, c226 1000mf35v, c228 1000mf35v todav?a continua la falla y al parecer los voltajes que alimentan a la tarjeta main y a la t-con est?n correctos la falla solo es en el sistema de encendido no tengo el software de actualizaci?n del equipo que pudiera ser una de las fallas, que me recomiendan revisar, gracias atte. Gabriel Espinosa M?xico gaboo65@gmail.com
Dec 30, 2012 | LG 26LC2D 26 in. LCD Television
Que significa SRS en el panel de mi mitsubishi mirage 1995
Hola:
EL codigo SRS se refiere al sistema de seguridad del vehiculo (Air Bag System), y aparece cuando se presenta algun codigo de falla en el mismo.
La presencia de un codigo de este tipo no sera eliminada con solo desconectar la bateria durante algunos minutos; necesariamente tendra que llevar el vehiculo a su representante o algun taller que cuente con lector de codigos (scanner) para determinar exactamente que codigo de falla se ha presentado, Solamente con este codigo podriamos ofrecerle mayores detalles.
Suerte.
Jul 10, 2012 | 1995 Mitsubishi Mirage
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Hola tengo una jeep liberty 2002 y me prende el foco del aceite cuando esta fria, le cambie el aceite hace un casi ya un mes y prende al acelerar y suelto y se apaga.
Podria tratarse de una falla con el sensor de presion de aceite, no el de nivel, sino el de presion. Intente escanear el computador a ver si aparece algun codigo de falla.
Suerte.
Feb 16, 2011 | 2002 Jeep Liberty
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Jul 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 42PF5321 42 in. EDTV-Ready Plasma Television Logo
614 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
