Question about Magic Chef Refrigerators
I have a Magic Chef refrigerator Model CTB1925GR and I need to adjust the freezer door(raise it on the right so that it seals properly
  • 828 Answers
On the top of the refrigerator is an adjustable hinge. You may have to pop of a cover plate to access the screws to loosen, make your adjustment and re-tighten.
Posted on May 17, 2008
WHATs the equivalent of a door gasket for this magic chef refrig?
get the right one from the spares deaprtment of the service shop
There are people like "Door Seal" or fridge seal replacers who can make a seal on site to fit the door
May 12, 2015 | Magic Chef Refrigerators
Have magic chef fridge w top freezer. Model number ctf2124ar. Ice build up in freezer near vents where fan blows air. Keeps coming back after I remove it. Anybody know what,s going on w it?
Ice build up in the freezer is usually caused by one of these problems. You may have an outside air leak from one of the door gaskets. Check the gaskets for proper seal and any cuts or pieces missing. Second possible problem may be your refrigerator is not self defrosting as it should. Cause of this could be a burned out defrost heater. With a bad defrost system, you normally will start to have your fresh food temps start to increase over time( about a week) and some food spoilage.
Mar 06, 2015 | Magic Chef Refrigerators
The freezer works properly but the lower part doesn't cool would you please help me
Set the freezer control to Warmest.(more air will go to fresh food)
Make sure the freezer fan is blowing.
Check the door seals on fresh food door especially on the bottom.(may be loose letting in warm air)
Aug 10, 2010 | Magic Chef CTB1821AR Top Freezer...
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
I found a water pool on the floor...
a coupltle thinges ,ur het plate to evaporate condensation it out, ur low on collant, or door sel is not sealing
May 30, 2010 | Magic Chef CTB2125 Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Putting refrigerator lock on freezer door
he may have punctured a freon line you will know for sure if it stops cooling.
Jan 31, 2009 | Magic Chef CTF2125 Top Freezer...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerators Logo
190 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
