Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
MY SIDE BY SIDE WAS REPAIRED WHILE ON VACATION AND AND WAS RUNNING COLD FOR A WEEK IN THE SHOP AND IN MY GARAGE. BUT WHEN I PLACED IT IN MY KITCHEN IT TRIPPED THE BREAKERS AND BACK TO WARM AIR NOW. IS THERE A RESET SWITCH ?
  • Whirlpool Master
  • 43,501 Answers
No, there is no reset switch...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 18, 2010
Code b223d
Then you have no air bag turned on, if you were to need it
Get it into a shop
Any dash light on after the motor is running, is a system fault,
& needs to be diagnosed & repaired within a week or less
May 14, 2014 | 2005 Chrysler PT Cruiser
Need replacement feet
You should be able to easily find replacement feet at a home improvement store. If you are looking for original parts then I would suggest ebay, craigslist or garage sales every week.
Sep 28, 2012 | Kartell maui side chair
We moved our side-by-side Kenmore from the kitchen to the garage yesterday and now it won't cool down. It was working fine before that. The compressor is running but is warm. We tried leveling it and...
hoe cold is it in the garrage?if it's cold wait till it gets warmer and it will work again or you could have knocked a wire off or damaged it somehow but it might just be to cold in the garrage.
Apr 12, 2011 | Kenmore Side by Side Refrigerator
Sears model 564.8780180
Try a new defrost timer..your mullion heaters are not on...
Aug 18, 2009 | Kenmore 53082 / 53084 Side by Side...
25 year old Whirlpool side by side fridge not cooling. Thermostat OK, both fans running, relay OK, overload protector stays closed 10 seconds or so then kicks out for a minute or so then closes again and...
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
May 01, 2009 | Whirlpool ES5FHAXS Side by Side...
The precise remote issue
Try holding down the wall button. If this does work the door as you hold it down then the problem is misaligned sensors. If it is not that then more than likely the logic board is not good. I have never seen a whisper drive that has a door bell button and only came with one remote though???Thanks BB
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
How can i drain all wter from a sears estate washer while a go o
disconnecting the hoses from under machine( usually pump hose is the lowest, all water should drain from machine, we used to place windshield washer fluid to hold them outside overwinter in used appliance store.
Nov 12, 2008 | Jenn-Air JCD2295HES Side by Side...
Can't Get in Garage
no remotes. new battery. why dont you have an emergency release in door. what would you do in case opener breaks or power failure. sorry, cant think of an answer.
Oct 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remotes don't work (3)
Did you inadvertantly hit the "vacation lock" button on the Mounted push button? This will cause the remotes not to work. Try hitting the button again, and then see if the blinking goes to solid green.
Good Luck
Jan 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
