Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My DD603 is flooding onto the floor and F1 is flashing/not turning off.
  • 205 Answers
You have probably figured out by now that the only way to stop it is to unplug it. The F1 code means that the Mains Filter flood sensor has been activated. There are a few reasons this may occur. 1. there was a large pan or dish that prevented the lid from closing fully, thus flooding. 2. the lid actuators, motors, did not close the lid completely and they need replacing. 3. the Link Support (holds the wires and hoses in place behind the drawer) has broken and is impeding the lid from closing fully. It and the lid would have to be replaced. These are the normal causes for the F1 error code. You will need to get a Tech out to have a look to determine the cause. Good luck.
Posted on Sep 24, 2010
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained ...do these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
http://www.appliancerepairlesson.com
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
No power in the dishwaher (it is plugged and yes power On)
If you didnt transport it home in an upright position,residual water may have gone down to the bottom of the cabinet and activated the flood switch(F1 =flood switch activated)To fix-FIRST UNPLUG FROM THE MAINS,so you dont get inadvertantly electrocuted.Remove the bottom drawer(there are tabs on either side of the draw that you need to push in and slide back about half way and lift the draw off the runners(refit by reverse procedure)
Carefully place draw to one side and on the LH side of the now exposed cavity you will see a grey ,white or black flattish plastic cover that will slide to the left and lift off to expose a credit card sized printed circuit board.on the LH end of that circuit board is the flood switch (the board is an upside down "L" shape and the flood switch is on the shorter part of the "L" that protudes down towards the floor(lowest point on the floor to detect any water in the event of a flood)remove the + shaped screw and CAREFULLY unplug the wires(noting their position down on a piece of paper )there is a latch that you have to push first before lifting out the credit card sized circuit board that is on the LH side of the board.Once removed mop up excess water on the floor of the cabinet and dry thoroughly the circuit board and wet cabinet area with a hairdrier.Then once totally satisfied its all completely dry,Refit the circuit board ,all the plugs(double checking they are correct and none missed out!)Refit the cover and refit the draw,Plug back in and hopefully that will solve the problem!
May 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
DD603 Does Seal need replacement? F1 Error Code
F1 error code appears because moisture has been detected by the flood switch on the base of the housing under the drawer.
If you think the door seal was not fitting properly then that too can cause moisture leak into base of the unit where the flood switch is located. Steam condensation would also lead to moisture.
Best option might be to replace the door seal for the top drawer. This is not a trivial thing as the unit has motor actuated door seal which can be tricky to fit back in.
Also avoid foaming in the detergent by using the correct powder and not tablets.
Please rate this solution if you are satisfied otherwise post a comment.
May 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher & Paykel dishdrawer dd603 is flashing f1
the flood switch at the base of the dishwasher has been activated. This means moisture has gone into the base (under the drawer).
Turn power off, and extend drawer to expose bottom back of the base. Use towels / hair dryer etc to dry it out.
Likely causes are - you used a wrong detergent (too much foam) or the hoses at the back are leaking or the actuator arm that supports the hoses when you pull or push the drawer is broken and the hose is kinked.
Hope you can fix it.
Dec 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Doulbe Draw model receiving an F1 error message.
F1 indicates flood switch has been activated. I wouldn't advise you attempt repair on these drawers- they really require an expert to disassemble (I worked for F+P for 10 years!!). Depending on which model you have (DD603 or DD601v2), repair varies. 603 has a small circuit board that acts as flood switch- located in base beneath drawer- requires drawer to be removed for access. 601v2 model has polystyrene float that acts as flood switch-leaks usually caused by split lid seal(tricky to access- drawer has to be removed) In either case, a leak has occurred and activated flood switch. These drawers are very sensitive to detergents (don't use tablets!!), and the way they are loaded.
Would suggest you get service technician to remedy F1 fault
Aug 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
My f & p dishdrawer model DD603 has fault code F1:
Yes, you need to gain access to the inside bottom panel of the dishdrawer and drain/dry the water in the bottom panel. When all of the water is gone the polystyrene block will lower and turn off the flood system. You then need to find the reason the unit flooded and rectify it or the unit will just do the same thing again.
Mar 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Dish drawer by fisher and paykel DD603 FPZW
flooded unit please remove drawer abnd dry board also read some of my other post on this problem
Jul 19, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
150 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
