Question about LG WD-1280FHD Front Load Washer
LG direct drive washing machine WM-16220FD
Seem to have something between drum and casing, scratchy sound when drum turned round, can we get into the drum to remove it.
    An expert whose answer gotĀ voted for 100 times.
  • 210 Answers
This is a fun task. Not sure of this model number, whether it has a heater or not, if it does you can remove the heater and attempt to get out whatever it is out through there. The other way is to remove the bottom bellows, drain out the water through the drain trap first, this will give you a bit of access. The easiet way is to take the front panel off, otherwise you would have to tip the unit back, securing it, and trying to access it that way.
good luck.
Sgt 48
Posted on Jun 04, 2008
Zanussi tc470
Jan 22, 2014 | Dryers
How do you disassemble the small drive gear on the PE550?
The small gear (part # 530071258) is attached to the clutch drum with a right-hand threaded cap screw (remove counter clockwise with an Allen wrench). It is secured with Locktite. To keep the clutch drum from turning while you remove the cap screw you must remove the transmission case from the edger (three long screws that are very hard to see and accessed from the blade side). The clutch drum has four holes in it -- you will use one of them to hold the drum from turning. Insert a 3/16 to 1/4 in drill thru one of the holes and drill a hole in the plastic transmission case, but not into the grease chamber. To keep the drum from turning, pass a screw driver or other round tool thru the hole in the drum and thru the hole in the case. Use the screw driver as a lever to keep the drum from turning and back out the cap screw counter clockwise. If the drum clutch becomes out of round you will have to replace it (part # 530036665).
Sep 02, 2011 | Poulan Pe550 Gas Edger
There seems to be something between the drum and the plastic outer casing of the drum. When the drum spins, there is a scraping noise and the object does seem to move inside the space. It doesn't hinder...
Most seals completely prevent clothing ie a tiny kids sock or other kids clothes. if it's bouncing about in side the exterior drum, something has broken and fallen inside there that shouldn't be.
Mine started with a wobbly spin, and ended up being a main spider gear that holds the wash drum inside the exterior drum perfectly with a watertight seal to a DD motor! A $240 dollar part shipped in saved the machine because the dryer has tons of miles left in it.
I used a video on Youtube to make the repair step by step including putting it back together again!
Self repair Rules!
Dec 12, 2017 | General Electric WSSH300G Front Load...
Scratchy volume potentiometer
Try cleaning your volume potentiomenter with contact cleaner (they come in spray can's), the scratchy sound is audible when you turn your volume control on, the contacts inside your potentiometer accumulated dust or some other particles.
Aug 11, 2010 | Alesis Sr 16 Stereo Drum Machine
Have you tried turning the drum with belt removed to see if sound is from drum or motor.If you cant get at belt easy thru. top ( make sure power is off) then you will have to split the casing which will give you a great view of all the moving parts to see if any loose parts.It may be that the bearings have gone so badly that it is clunking as it turns.Normal bearing failure noise is a rumbling.
Remove 2 screws at rear underside of top lid and remove.On top middle either side by springs remove the 4 screws holding back panel,down below at rear there is normally 2 or 3 screws on corners of panel,now go to side of panel bottom middle by seam and remove round white plastic covers put small screwdriver in hole and pull out there is a screw behind each (8mm small socket).Now by water inlet valves prise out white plastic housing with valves still inside now put screw driver in spli on side panel either side and work it back you will have to hold down drain hose to clear panel,once off you can inspect for any damage or loose parts,check drum pulley is not loose or worn,check motor also concrete balance weights one on back top of drum casing and one at front around door seal,sometimes these come loose.To refit casing it is a reverse of removal.
Hopefully this will be helpful.
Good Luck.
May 05, 2010 | Zanussi FLA1001W Front Load Washer
Frigidare ftw 647ghso thumping sound in one spot when i manually rotate drum sounds like its rubbing on something
Suspect a bad drum bearing or bent drum bearing shaft. When you rotate the drum, look for movement of the drum up or down while turning. If the drum moves suddenly, suspect the drum bearing. If it slowly moves up or down during turning, suspect a bent shaft on the drum. In either case, it is a major teardown to remove the drum from the outer drum case. If still under warranty, take advantage! Hope this helps!
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
My WD440 has trown its drive belt and something
it sounds like there is a sock or something simular stuck between the drum and tank,the paddle is removable which may help you hook out the item,if you grab the drum paddle from the rear and pull it towards you it will then lift up,once you have removed the offending item,you just line up the slots on the drum with the pegs on the paddle and push towards the rear of the machine and you will here a click,this means the paddle is secure.
Aug 02, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer is making a scratchy, grinding sound when turning.
some where there's somthing of the drum draging metal to metal.could be the drum glides are worn or the felt need to remove the front and pull the drum and inspect.unplug unit before tring.if need more help you can email. God bless ,tom ps the stains are the metal shavings ground to a pulp
Jan 10, 2009 | Maytag Dryers
LG WD-1280FHD Front Load Washer Logo
355 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
