Question about Sony KP-46S25 TV
Hi, I plug in the sony KP-46s25 in to 120 volts, the high voltage comes on automatically and will not shut off at the on/off button and the red, blue and green tubs comes on for 2 seconds and then off. The sound also comes on. If I change channels 4 or 5 times to find a signal the sound will shut down. The only way to stop the high voltage is to unplug the sony KP-46s25. The Problem is in the power supply board. The 12v standby voltage is some how crossing over somewhere and turn on the relay, which turns on all the voltages on the power supply board. I check just about every part on the power supply board, I can't find the bad part. I took the G board out and put it on the table. check all the voltages. all voltages are there, but 18v is low like 10v. when the G board is in the set there is no voltege at the relay pin going in to the G board. I unplug the wire from the relay in pin on the G board and tested that wire and it was 5v coming out. when I push on the on/off button on the front of the set, the 5v from the wire would go on and off like it is supposed to. I replaced The Q655 2sa1048TP RY- Drive anyway, no luck. This is Sony KP-46s25 1996 I do thank you for any help, Derral
  • 47 more comments
  • Derral Sep 19, 2010
    Confirm the voltage of G BOARD TP135V is less than
    137.0Vdc.
    I will post for more once your B is OK
    Voltage of G BOARD TP135V is 136.2Vdc this is with no load on it.
  • Derral Sep 21, 2010
    Could you send me a copy of your G board schematics please.
    Would like to see what else is different on my schematics.
    Send an attachment in this email address: groves71955@aol.com
    Sure would appreciate it.
    Thank you,
    Derral
    Thank you,
    Derral
    Thank you,
    Derral
    Thank you,
    Derral
    I am still waiting for the part to get here that i ordered for Q655 2sc2458tp
    Will talk to you soon.
  • Derral Sep 22, 2010
    My transistors is different than your transistors on the schematics
    Q662, Q653, Q652 are different part numbers on the part.
    http://www.directcarinsuranceinfo.com/Re...
    what should I do replace the ones I have with the ones you have?
    This tv came from a TV repair shop, I bought it from the person how got it from the tv repair shop.
    They both worked on it. So this is what I get. I thank thay used the same schematics that I am using.
    Mine are Q662 NPN 2SC2458TP Q653 PNP 2SA1048TP Q652 NPN 2SC2458TP
    Yours are Q662 PNP 2SA1048TP Q653 NPN 2SC2458TP Q652 PNP 2SA1048TP
  • Derral Oct 01, 2010
    Hi, ok replace the Q655 with: 2sc2458 NPN. And replaced IC 651
    Now the Power Supply works like it's supost to.
    The promlum now is: when I plugged in the 120ACV the TV will come on automatically.
    when I push the off button the TV will go off, when I push the on button the TV will come on.
    The on and off works like it's supposed to. Except when I first plug it in.
    On and off works, Vol up and down
  • Derral Oct 03, 2010
    I checked the Q652 it is good it is a : 2sc2458TP
    I checked the Q653 it is good it is a: 2SA1048TP
    With the Power Supply board put back in the TV B is 132V
  • Derral Oct 04, 2010
    Hi, I will change this right a way, thank you.
    -- just hope you have read what i have posted earlier-
    Q652 should be PNP
    -Q653 should be NPN
    Should I also replace the Q662 - NPN - 2SC2458TP- - With a - PNP - 2SA1048TP-
    While I am replacing - Q652
  • Derral Oct 05, 2010
    Almost does the same thang after changing Q662 to: PNP 2SA1048TP
  • Derral Oct 06, 2010
    I dont thank you are seeing my full post I am puting on here.
    Dont no why the hole post is not showing.
    Go here to see the hole post : http://www.directcarinsuranceinfo.com/Re... Parts.html
    This link works
    This link works Go here to see the hole post :http://www.directcarinsuranceinfo.com/Re...
  • Derral Oct 07, 2010
    Hi, did you read this post here?: http://www.directcarinsuranceinfo.com/Re...
  • Derral Oct 08, 2010
    Hi, I am waiting for the parts to get here that I ordered for Q601
    R632 is going to emitter of Q652. - And R660 is coming from the
    bases of Q652. and the other end of R660 is going to R672-- and
    the other end of R672 is going to the collector of Q653.
    and the emitter of Q653 is going to ground. -
    And number 3 of IC652 is going to the emitter of Q662.
    And the base of Q662 is going to D688.
    could you be more specific about what this is and where
    it is please: 78XX regulator
    The IC652, part number on the part is: T7812CT
    R632 is going to emitter of Q652. - And R660 is coming from the bases of Q652. and the other end of R660 is going to R672-- and the other end of R672 is going to the collector of Q653. and the emitter of Q653 is going to ground. - And number 3 of IC652 is going to the emitter of Q662. And the base of Q662 is going to D688.
    Hi, just to let you know I work on tv avery now and then just as a hobby.
    I buy this tv for my son to have to play his games on.
    not in a big hurry to get fix, but he is.
    we had a 46" RCA but it died, so we are working on this sony.
  • Derral Oct 09, 2010
    I have a:
    Sony KP-46S25 Service Manual
    RA-1 Chassis No. SCC-H53J-A
    I have paper
  • Derral Oct 11, 2010
    This RCA P46924
    I replace the flyback and horizontal.
    Convergence was off, went in to Services mold to adjust.
    could not get it to adjust a nuff to be good.
    Dont have a RCA chipper tool to do the rest of the convergence.
    The price for one would not be worth it.http://www.mcmelectronics.com/product/RC...
    So I stop working on it.
  • Derral Oct 12, 2010
    Yes the convergence power supply has the right output voltages on it.
  • Derral Oct 13, 2010
    Hi, still waiting for the parts for Sony KP-46S25.
    Your order was sent on Oct 8, there is no tracking number for
    your order. You should receive it in about 5-7 business days.
    I dont have a service manual. I have a CTC195Trainmanual.pdf
  • Derral Oct 17, 2010
    Hi, ok are these transistors collector, emitter
  • Derral Oct 19, 2010
    Hay what happened to my electronics partner?
    Do I have to go it alone now?
    What's the dill?
    What's the dill?
    What's the dill?
    What's the dill?
  • Derral Oct 29, 2010
    Hi, do you have the Sony_blink_codes for this tv.
    Thank you,
    Derral
  • Derral Nov 01, 2010
    Hi, do you have the sony blinking codes for this set.
    Thank you,
    Derral
  • Derral Nov 22, 2010
    Hi, I got parts for power supplies but it blew out Q601
  • Derral Nov 23, 2010
  • Derral Nov 24, 2010
  • Derral Nov 25, 2010
  • Derral Dec 01, 2010
    The troubleshooting code flashes 4 times
    The troubleshooting code flashes 4 times.
  • Derral Dec 08, 2010
    I have 23 blinks
  • Sony Master
  • 5,807 Answers
137.0Vdc.
I will post for more once your B+ is OK
Posted on Sep 18, 2010
  • 60 more comments
  • Rommel Cana
    Rommel Cana Sep 18, 2010
    here is the first one :
    you should be having 12V here:
  • Rommel Cana
    And here is your Relay drive:
    Never bypassed or short the Collector and emitter of the Relay Drive
    till B+ is OK
  • Rommel Cana
    Your 18V starts here:
  • Rommel Cana
    And is driven by these Circuits:
  • Rommel Cana
    which is controlled by:
  • Rommel Cana
    It has 12.3V
    Dont now wow to put my pictures here.
    This is the Relay drive on my schematics
    Mine looks like your Q656 transistor diagram.
    it is different for some reason. Don't Know Why. Everything else looks the same.
    your is: 2sc2458tp NPN
    mine is: 2sa1048tp This is a PNP
    What do we do?
    What do we do?
    What do we do?
    What do we do?
    What do we do?
    At this pont it is: 10.89V
  • Rommel Cana
    Rommel Cana Sep 19, 2010
    I understand if you have not read all my post:
    and these is it again:
    have you check the diode and the capacitor?
    If the other side of the relay goes to emitter it is PNP
    But if it goes to Collector it is NPN
  • Rommel Cana
    On your browser:
    you can insert pictures no more than 150KB
    or you can post a link where i can view.
  • Rommel Cana
    Another alternative is to supply the 18V with a separate power supply and check
    if voltage is the same .
    If it do , then you may have to check further , till you found the cause.
    ( if it not the diode and the capacitor )
  • Rommel Cana
    since you have a 12V then here is the back up of 18V
    unless D688 is open
  • Rommel Cana
    And these could be the reason by you are only having about 10.89V
    if diode and capacitor is OK
  • Rommel Cana
    Going back to your Relay drive ,
    Where is the other pin of relay connected ?
    Is it on the Emitter or Collector?
    It goes to Collector. I have to get the right one to put in.
  • Rommel Cana
    Basing on your schematic , yours is a PNP
    It is connected on the Emitter
    have you checked the diode and the capacitor?
  • Rommel Cana
    here is your guide for 2SA1048
    [PDF]
    2SA1048
    The tracer gos from pin 3 off the 12v Reg to the RY602.
    The other side of the relay tracer goes to collector of Q655.
    The emitter is ground.
    The diode and the capacitor are good.
    The emitter is ground on Q655.
    Cant tell if this reply is loading up or not.
  • Rommel Cana
    do you have the external power supply ?
    and if you do try to connect it , to test
  • Rommel Cana
    just like i posted above, if the relay is connected on the Collector it is NPN
  • Rommel Cana
    pin out for 2SC2458 is the same as 2SA1048
  • Rommel Cana
    Rommel Cana Sep 20, 2010
    have you checked Q662 and other small transistors?
  • Derral Sep 20, 2010
    I put Q662 2sc2458 transistor in the Q655 place, left Q662 with nothing in it. Put 12v to pin 3 of the 12v Reg to get 12v standby.
    Then I put 12v to pin 3 of cn653 "Relay" win I did the relay terned on and off like it supposed to.
    I will order this part, when I get it I will get back with you.
    Talk to you soon
    Derral
  • Rommel Cana
    Rommel Cana Sep 21, 2010
    here are small transistors to check:
  • Rommel Cana
    additional small transistors:
  • Rommel Cana
    You really need a separate or external power supply,
    a ) first you have to insure that the circuits after the diode D664 is OK. ( 18V )
    you can safely use 12V @ 1A
    b ) these will actually test your many zener diodes on the G Board, by
    connecting in series with at least 1K resistor , to determine if OK
    I am sorry I cannot send attachments right away to your email address, I will have to
    ask permission , but that would take more time , depending on their response.
    You may also ask them to permit me or allow after passing through them.
    I am sorry for the inconvenience to you.
    But I can send more images , just tell me what part so i can post larger
  • Rommel Cana
    here is your guide:
    Check D691 as well ,
  • Rommel Cana
    You might also consider checking these later:
  • Rommel Cana
    Rommel Cana Sep 22, 2010
    The relay will not latch if the Relay Terminal is connected to PNP transistor in Collector
    but on emitter it will work ( collector should be to ground )
  • Rommel Cana
    then these NPN driver transistor ( relay ) should be connected to the Collector
    the only difference is that your schematics do not have the NPN driver.
    Let us follow what and where are the components connected accordingly, not according to your
    schematic but according to your board
  • Rommel Cana
    What I am basing is about where it is connected, and through the service manual,
    You can check and confirm on your former owner if yours is the same.
  • Rommel Cana
    here are some additional guides:
    [PDF]
    Transistor Relay Driver Demo
  • Rommel Cana
    try to use what i have posted, if the unit does not previously worked when you have .
  • Rommel Cana
    Q662 is just a " back up " transistor , should be PNP,
    these transistor only works at these conditions
    a ) when the relay is driven ( latch ) by NPN driver transistor
    base voltage is lesser than emitter voltage ( PNP )
    b ) when there is supply on its emitter ( 12 V )
    c ) D608 is good same with resistor R636
  • Rommel Cana
    On Q652 it must also be PNP
    these transistor is just for " Soft Start ", it is triggered when the relay have latched
    there are also zener diode with it.
    To properly check the drive relay,
    use a separate power supply , Inject a voltage with a series 1K to 4.7K to the base and it will
    latch your relay ( NPN driver not PNP )
  • Rommel Cana
    Have you checked these out ?
    If you will still be having like 10V on the 18V line?
    You can hang one side of the resistor ( R633 ) if you are using a separate power supply
    just to determine if these IC drains the supply of 18V
  • Rommel Cana
    These Q652 is driven by these transistor
  • Rommel Cana
    Rommel Cana Oct 01, 2010
    glad to know it is working ,
    have you checked for the supposed transistor ( next to the IC651 ) on my post? Q652?
    and replaced your board with 2SA1048?
    same with Q653?
    I just hope you have read all my post
  • Rommel Cana
    Rommel Cana Oct 03, 2010
    i just hope you have read what i have posted earlier
    Q652 should be PNP
    Q653 should be NPN
  • Rommel Cana
    Rommel Cana Oct 04, 2010
    Q652 should be PNP ( 2SA1048 )
    Q653 should be NPN ( 2SC2458 )
  • Rommel Cana
    Rommel Cana Oct 05, 2010
    Yes,
    details have already been posted above
  • Rommel Cana
    Rommel Cana Oct 06, 2010
    have you replaced Q652 and Q653?
  • Rommel Cana
    connect or use a set top box , to the audio and video In , not on the RF antenna.
    ( or use a DVD or VCD or VCR or a video camera ) just for troubleshooting
  • Rommel Cana
    Rommel Cana Oct 07, 2010
    you may have to go back from the beginning of these post,
    and confirm that your flyback
    http://www.fixya.com/support/r3704932-a_... is oscillating
  • Rommel Cana
    trace what is connected to R632, is it collector or emitter?
    trace what is connected on out of 78XX regulator,
    and post voltages again on your B
  • Rommel Cana
    Rommel Cana Oct 08, 2010
    while you are waiting have some time tracing for the transistor s I have mentioned above,
    and take your time ( post a day ago ) regards
  • Rommel Cana
    it is the IC652 , supposed to be 7812, what is yours ( board), thanks
  • Rommel Cana
    Rommel Cana Oct 09, 2010
    OK, it is the samehttp://www.datasheetcatalog.com/datashee...
    http://hct.ece.ubc.ca/research/sidgroove...
  • Rommel Cana
    what is the problem with your 46" RCA , have you tried to open on it?
  • Rommel Cana
    Rommel Cana Oct 11, 2010
    have you checked the convergence power supply? does it have the necessary output voltages
    on it?
  • Rommel Cana
    Rommel Cana Oct 13, 2010
    have you tried procedures on pages 1-B5 service manual to 1-B6
  • Rommel Cana
    Rommel Cana Oct 22, 2010
    back again,
    went to province, to my parents
  • Rommel Cana
    Rommel Cana Nov 03, 2010
    how many blinks do you have?
I have a sony big screen tv kp 51ws510 there is a small board on the left of the tv which in the center of it has a small black box part no dslu1 12vdc025w 5a/100 that clicks every tine I try and turn on...
On the bottom of the photo, the large capacitor with two small blue capacitors to the left, need to check the voltage (should be close to 400 volts); is failing if there are only 380 volts. Today's TVs are like computers, and the high voltage circuit is checked and if it does not have the proper voltage the TV will shutdown.
Nov 02, 2017 | Televison & Video
My sony kp- fx532m91 has trouble in turning on it takes 30 to 60 minutes before it will open/on. and it blinks six time every 3seconds. what could be a possible remedy anyone can help me.
Iam thinking that 6 blinks means power suply make sure all voltages are right according to the board.Could be somthing is pulling down on 5 volt line or12 volt line. If it is a CRT which Iam sure it is then there is 150 volts DC or so for the flyback there is a high voltage block for the high voltage for each gun red blue and green.Check power suply horizontal output high voltage block focus and screen block.
Nov 21, 2013 | Televison & Video
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Power shuts down after 30 sec.also red light flashes 5 times weather on or off/ sony kp46wt500
5 blinks states faulty on CRT baseboard circuitry where the video signal is amplified. A bad video amplifier IC, loose solder connection or Absence of 200 volts and G2 voltages.If 200v or G2 voltages were not present, look for the resistor block for screen and focus adjustment. try to adjust the screen voltage of each crt...
Feb 15, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My Sony KP 51W520 won't come on. The standby light flashes 10 times. I read through the other people's problems listed here and everyone else has had either 3 blinks or 9. Any thoughts?
Hi.
it seems that your power supply or high voltage section is failing. Look for PWM IC genarator. MCZ 3001D on Power supply and near high voltage section. Try to replace these IC's.
Jan 05, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
KP-43HT20
If the flyback is bad, the 135 volts will reach about 70 or 80 volts and the set will shut down, and the LED will blink twice. Usually, for 8 blinks, the high voltage capacitor inisde the splitter is shorted, and an easy test for this is to disconnect the thin gray ground wire, move it away from everything else and turn the set on. The set will now run but the ground wire will hiss like crazy. If you replaced the splitter but the set will not run, try disconnecting the 3 high voltage wires to the CRT's and see if the set runs. If it does, reconnect the high voltage wires one by one until you find which CRT is loading down the high voltage. Let me know how you make out.
Apr 09, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Televison & Video Logo
442 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
