Question about Kicker KX650.4 Car Audio Amplifier
I have a kicker kx650.4 that needs a new r71 resistor unknow value it is burnt can anyone help please
Help ID this surface mount componant
That's a burnt resistor. I would guess that is not the only part that is bad. You have a short on the board. There is no way to read the value anymore. I'm afraid you are looking at a new motherboard. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 24, 2013 | ASUS G1SN-A1 Gaming Notebook PC
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
Burnt out resistor
I have put a 1k 1/4w resistor in place and all is working
Sep 09, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Resistor values
Request a schematic diagram and parts list from Kicker.
Jul 15, 2017 | Kicker ZX650.4 Car Audio Amplifier
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Mar 16, 2008 | Computers & Internet
Resistance value
plz send model number of monitor
Mar 09, 2008 | ViewSonic E55 15" CRT Monitor
Kicker KX650.4 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
