Question about Garden
I have sand as a base and want to cement between rocks for a more stable walkway
  • 490 Answers
Put the cement under the rocks as well or it will break up in a very short time.
Farmerbear
Posted on Sep 17, 2010
How to remove cment stains from walkway tilese?
cement is reduced by hydrochloric acid
so test with a spare tile first to see if the acid affects the tile surface
place a few deops of the acid in a container of water and use a cloth to wipe over the cement stain
make sure that you use rubber gloves
keep adding a few drops until you see the cement start to beak down
Mar 03, 2018 | Washing Machines
I am laying a walkway with paving stones. If I add 2 inch of sand to 375 sq feet of space, how much cubic ft of sand will I require?
Since a cubic foot is 12" x 12" x 12", if you were to make the sand 12" thick you would have 375 cubic feet of sand. However, since you want your sand 2" thick (which is 1/6th of a foot), you simply divide the 375 by 6 to get the value of sand in cubic feet (62.5).
Nov 17, 2016 | Office Equipment & Supplies
The mixture of sand and cement for laying bricks
mortar proportions are always expressed as a proportion of cement to lime to sand and always in that order
common mortar made from portland cement has one part cement to one part lime and 6 parts sand ===1:1:6
Cement bags have the mix written on the side for mortar mix or concrete mix or you can get mortar mix cement which already has the lime added
Oct 22, 2016 | Washing Machines
What is the correct ratio for mixing concrete?
generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Jan 15, 2013 | Building Materials
Three lights work out of seven after I reinstalled them after cement walkway was put in
I don't know if wire is damaged, connections are bad, or bulbs burned out.
Best to test each.
Copy following link for general troubleshoot resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 07, 2012 | Intermatic Ml121rt Malibu 121-watt Power...
What is the sand and cement mix ratio for a patio
Hello. The typical volume-ratio for a self-mix concrete in this application would be one part Portland cement to three parts sand. For a stronger pad (capable of higher stress loads) it would be as low as two parts sand, but this is not necessary for a standard patio pour. The gravel should be three parts, more will make it tougher to achieve a smooth finish. Re-cap: Portland cement - 1 part, sand - 2 or 3 parts, gravel - 3 parts. Hope this helped.
Apr 12, 2011 | Garden
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
