How do you reset an apple macbook laptop - Computers & Internet
  • 570 Answers
Don't worry just follow the below steps and you will be able to fix your problem
Back up your information to an external medium such as an external hard drive or a flash drive. The install process allows you to transfer current files to a fresh operating system (OS) install, but it is always best to be prepared with a backup of your files in case something goes wrong.
Insert the first install CD or DVD of the operating system software.
Restart your Mac Book or Mac Book Pro. Immediately hold down the "C" key as the computer reboots. This will cause your Mac Book to boot from the CD or DVD you inserted.
See the "Welcome" dialog that asks you to pick a language. It may also ask you to agree to the terms and conditions of the software install. Depending upon which OS version you are using, you might see the software perform several checks on your system. If you do not see this, do not worry.
5
Choose where to install the OS. You're most likely going to select your primary hard drive. If you have one or more partitions on your hard drive, you can select any of them as long as they are large enough.
6
Choose your install. You'll be presented with three options: "Upgrade," "Archive and Install," and "Erase and Install."
Choose "Update" to simply update the current OS install on your Mac Book. All your data, files and programs will remain intact.
Choose "Archive and Install" if you need to back up all the data on your system and import it into a fresh install of the software. You will need to reinstall much of your non-Apple software if you choose this option.
Pick "Erase and Install" if you want to erase everything on your hard drive and install a fresh version of the OS. None of your data will remain if you pick this option. This is effectively a factory reset of your Mac Book, as none of your personal settings or data will remain.
7
Choose the right setting. If you choose "Archive and Install," be sure to check the box to preserve your user and network settings. This will ensure your previous profile data is installed in the new software installation. Once you've chosen an option, select it. Click "OK."
8
Relax. The Apple OS install will take care of everything from this point. You may be prompted along the way with a few questions, but the install should be mostly automatic. When the install is complete, your Mac Book will restart.
9
Restore your data. If you chose "Upgrade" or "Archive and Install," the software will prompt you to migrate your old data to the new system. Follow the instructions to ensure your old settings and programs are transferred to the fresh install of the software.
Thanks.
Have a great day
Posted on Sep 17, 2010
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
Reset macbook pmu
An Intel-based MacBook uses an SMC rather than a PMU. If you need to reset the SMC, follow these instructions. Intel based Macs Resetting the System Management Controller SMC
Dec 21, 2013 | Apple MacBook MB403LL/A White - 2.4GHz...
How i reset apple macbook air 4 digit pin code
Follow these Simple steps to reset your Apple MacBook Air - http://www.ehow.com/how_6934095_reset-macbook-air.html
and share any Mac problem with Apple Customer Service for help.
Apr 19, 2013 | Apple MacBook Pro Notebook
Hello:
1) What model and what year is your Macbook Pro?
2) What country are you in?
3) Is your Macbook still under warranty? That is, can you call Apple or send it to Apple for repair if you have to? Because on some Macbook Pros, only Apple can reset the EFI PIN
How can i reset an apple macbook pro without the software?
Press the Apple Key/Alt Key/P/R
All 4 of those keys pressed, power on, heep holding, the apple sound will go off.. keep holding... let the apple sound play 3 times, then let go of the 4 keys...
Done....
Dec 20, 2009 | Apple MacBook Pro Laptop Computer with...
Apple Remote Not Working
Have you installed anything in between time? (i.e.,Software updates, 3rd party drivers.) Have you cleaned or organized your hd and "got rid of things you don't use/need ?" Has the laptop been serviced or opened?
Try resetting the MacBook's PMU (power management, hold down power button while the battery is out and the cord is unplugged) and possibly resetting the PRAM (hold down command + option + p + r before you hear the startup chime, it should start again, let it boot from there).
Sep 02, 2008 | Apple MacBook Mac Notebook
Macbook pro sleep problem
Reset PMU and P-Ram.
http://docs.info.apple.com/article.html?artnum=2238
http://docs.info.apple.com/article.html?artnum=14449
Apr 17, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
